APR Presents: Audi TT RS 2.5 TFSI ECU Upgrade!
Arin@APR Dec 15, 2010
  1. Arin@APR
    Arin@APR New Member
    13
    Product Page
    APR is pleased to present the ultimate ECU Upgrade for the Audi TT RS 2.5 TFSI.
    After months of long nights and many hours of testing, development and more
    testing, we are pleased to offer you an ECU recalibration that is second to none.
    APR's extensive research and development provides you with a powerful ECU
    Upgrade with no loss of drivability or reliability. Expect tremendous increases in
    power and torque across the entire power band, improved throttle response and
    a smoother, more powerful top end.
    The TT RS's engine management presented new challenges to the Engineering
    Teams at APR in the form of new control strategies for torque management.
    Significant time was spent researching these new strategies to properly request
    more load and therefore more boost in the lower end of the power band. The
    results were simple, a torque curve that crushes the competition and delivers a
    rush of power like no other in the industry.
    The Audi TT RS 2.5 TFSI ECU Upgrade is an expertly recalibrated engine control
    strategy that remaps boost, timing, air fuel ratios and other engine management
    paramaters to provide smooth and reliable power as if intended by the OEM.
    APR's ECU Upgrade is developed to work within the OEM and Tier 1 Supplier
    specifications for engine component stress tolerances and performance
    specifications. APR's ECU Upgrades are available in octane specific versions
    to allow you to take full advantage of the fuel quality available in your area.
    Stage I ECU Upgrade
    Not only does our Stage I ECU Upgrade give you higher peak numbers of
    451 horsepower and 516 ft-lbs of torque, but also gains of up to 150
    horsepower and 189lb-ft are available at lower RPM's with 104 RON!
    APR's ECU Upgrade is the best power per dollar modification for the new
    2.5 TFSI and gives it just the extra edge these cars lack from the factory
    without pushing the limits. With factory like smoothness and drivability
    APR's ECU Upgrade will fill the void in an otherwise excellent car.
    APR Stage I ECU Upgrade Calibration Report
    Stock
    As Reported by Audi
    338 HP
    332 TQ
    Stock
    As Measured by APR
    352 HP
    341 TQ
    98 Octane RON
    403 HP
    462 HP
    +106 HP @ 4150 RPM
    +134 TQ @ 4150 RPM
    104 Octane RON
    451 HP
    516 TQ
    +150 HP @ 4300 RPM
    +189 TQ @ 4000 RPM
    Application Guide
    All Audi TT RS 2.5 TFSI's in 6MT or S-Tronic.
    ECU programmed through Direct Port Programming.
    ECU does NOT need to be removed.
    Please contact a local APR Dealer to purchase
    or visit www.GoAPR.com for an order form!
  2. goon
    goon Member
    332
    hope its better than the remap on my a4,total waste of time that was.
  3. A3SBQ
    A3SBQ A3 SportBack 2TFSI quattro DSG
    479
    74
    Whats TTRS guys thoughts on this? A friend of mine is getting the APR stage 1 ECU map.
    It's a S-tronic car as well. Any problems with the DQ500 box?
