APR Audi A4 (B8) 2.0 TFSI Valve-Lift ECU Upgrade Released!
Arin@APR May 18, 2009
  1. Arin@APR
    Arin@APR New Member
    13
    Product Page
    APR is pleased to present the ultimate ECU Upgrade for the 2.0 TFSI Valve Lift engine. After months of long nights
    and many hours of testing, development and more testing, we are pleased to offer you an ECU recalibration that is
    second to none. APR's extensive research and development provides you with a powerful ECU Upgrade with no loss of
    drivability or reliability. Expect huge increases in low-end torque, improved throttle response and a smoother, more
    powerful top end.
    The APR 2.0 TFSI Valve Lift ECU Upgrade is an expertly recalibrated engine control strategy that remaps the boost
    pressure, timing and air fuel ratios to provide smooth and reliable power as if intended by the OEM. APR's ECU
    Upgrade is developed to work within the OEM and Tier 1 Supplier specifications for engine component stress
    tolerances and performance specifications. APR's ECU Upgrades are available in octane specific versions to allow you
    to take full advantage of the fuel quality available in your area. APR's patented EMCS functionality puts the control of
    the engine's operation at your finger tips and allows for additional features and options to be installed to your OEM
    ECU.
    Not only does our Stage I ECU Upgrade give you higher peak numbers of 234 horsepower and 333lb-ft. of torque, but
    also gains of up to 40 horsepower and 71lb-ft are available throughout the power band! APR's ECU Upgrade is the
    best power per dollar modification for the new 2.0 TFSI Valve Lift and gives it just the extra edge these cars lack from
    the factory without pushing the limits. With factory like smoothness and drivability APR's ECU Upgrade will fill the void
    in an otherwise excellent car..
    APR Stage I ECU Upgrade vs Stock - 100 Octane Dyno Performance
    APR Stage I ECU Upgrade vs Stock - 93 Octane Dyno Performance
    APR Stage I ECU Upgrade vs Stock - 91 Octane Dyno Performance
    NOTE Do not be fooled by claims from lesser tuners, a transmission reflash IS NOT Required to achieve the advertised power claims with an APR ECU Upgrade.
    APR Stage I ECU Upgrade Calibration Report
    Rev Limit (RPM)
    Stock - 6800 RPM
    APR Stage I 91 Octane - 6800 RPM
    APR Stage I 93 Octane - 6800 RPM
    APR Stage I 100 Octane - 6800 RPM
    Speed Limit (MPH)
    Stock - 130 MPH
    APR Stage I 91 Octane - Unlimited
    APR Stage I 93 Octane - Unlimited
    APR Stage I 100 Octane - Unlimited
    Power (HP)
    Stock - 212 HP
    APR Stage I 91 Octane - 229 HP
    APR Stage I 93 Octane - 234 HP
    APR Stage I 100 Octane - 268 HP
    Torque (LB-FT)
    Stock - 260 TQ
    APR Stage I 91 Octane - 323 TQ
    APR Stage I 93 Octane - 333 TQ
    APR Stage I 100 Octane - 338 TQ
    Peak Gain from Stock (HP@RPM)
    APR Stage I 91 Octane - 35 HP @ 5500 RPM
    APR Stage I 93 Octane - 40 HP @ 5500 RPM
    APR Stage I 100 Octane - 62 HP @ 5500 RPM
    Peak Gain from Stock (TQ@RPM)
    APR Stage I 91 Octane - 64 TQ @ 2250 RPM
    APR Stage I 93 Octane - 74 TQ @ 2250 RPM
    APR Stage I 100 Octane - 78 TQ @ 2500 RPM
    Available for the following Vehicles:
    2009+ B8 Audi A4 2.0 TFSI.
    Quattro or FrontTrak
    Tiptronic or 6-Manual
    Compatible with Driveselect
    Price:
    $599
    FREE TRIAL SOFTWARE!
    *SPECIAL INTRODUCTRY PRICING - Until June 20th, 2009 all customers will be upgraded to a fully loaded ECU
    Upgrade for FREE. A fully loaded ECU Upgrade includes all of the EMCS options listed below.
    Program Switching Technology
    For a total of 2 programs (i.e. - Stock and Chipped) Normally: $149 Special: FREE!
    For a total of 3 programs Normally: $219 Special: FREE!
    For a total of 4 programs Normally: $289 Special: FREE!
    Other Available Options
    Security Lockout Normally: $59 Special: FREE!
    Fault Code Erase/Throttle Body Alignment (FCE/TBA) Normally: $59 Special: FREE!
    Anti-Theft System Normally: $199 Special: FREE!
    EMCS
    EMCS is APR's revolutionary patented Enhanced Modular Chipping System. EMCS is an industry leading technology
    that brings many new features to the automotive enthusiast. This technology was developed exclusively by Audi
    Performance & Racing, LLC and demonstrates APR's continued commitment to lead the industry with the most
    technologically advanced products available.
    Want chipped mode? Want to be able to switch back to your stock settings? Want a race mode to run 100 octane fuel
    at the track? How about a valet mode that limits power? EMCS is the lone technology on the market that can give you
    all of these options. No changing of the chip or ECU is required. These programs are available at the touch of a button.
    Other companies have attempted to imitate EMCS with clumsy external switching devices that only replace portions of
    a "base" calibration. EMCS is still the only Bosch Motronic Engine Management System enhancement that gives the
    ECU the ability to completely rewrite the entire operating map data when selecting different programming options.
    This allows for completely new and independent calibrations for each program selected giving you the best, most
    powerful and complete Stock Modes, 91, 93 and 100 octane Performance Modes and Valet Modes.
    APR's EMCS features and program modes are activated via your OEM cruise control buttons for ease of use and
    stealth. Your cruise control will continue to function as normal, but will give you the ability to scroll through the
    programs you have purchased with your APR ECU Upgrade. The procedure is simple and involves only two steps.
    How EMCS Works
    Step 1
    Press and hold the "set" button on your cruise control. After approximately five seconds, the "check engine" light on
    your dash will begin to blink once per second. This will tell you that you are activating program one. This blinking
    sequence will continue for approximately five seconds.
    After this five second interval, the "check engine" light will begin blinking twice per second. This will indicate that you
    have activated the second program. This process is continued to access any remaining programs you may have
    purchased. (three blinks = program three, four blinks = program four).''
    Step 2
    Once you have activated the desired program, simply release the "set" button. The "check engine" light will stop
    flashing. Turn the ignition key off for 10 seconds, turn the key back on, and you will be locked in that program until
    you change it again.
    It's that simple.
    Available Features
    APR's EMCS is a truly modular system that allows for future enhancements and features to be added as they are
    developed without the need for additional hardware. EMCS makes the following advanced features possible:
    * Program Switching Enables you to swap between two or more engine programs using the cruise control
    stalk. All cars have stock and standard chipped program versions available. Valet, race-gas, and other specialty
    programs are available for most models.
    * Fault Code Erase/Throttle Body Alignment (FCE/TBA) Fault Code Erase allows you to erase and reset
    engine related trouble codes without having to use a specialty tool. Throttle Body Alignment allows you to manually
    perform throttle-body adaptation.
    * Security Lockout Prevents unauthorized personnel from accessing EMCS functions. The user may select
    any 2 to 4 digit security code. The security code is entered using the cruise control buttons.
    * Anti-Theft You can render your car immobile to thieves, even if there is an attempt to start the car with
    your own key! For more information about Anti-Theft, click here.
    Installation Options
    APR's ECU Upgrade is able to be installed by APR's professional dealer network or by APR directly. Most late model
    applications are available to be installed via DirectPort programming without removing your ECU or even opening the
    hood. DirectPort Programming is not available for all models and in these rare cases EMCS Modules are able to be
    soldered to the ECU. In the event there is not an APR dealer near, you also
    have the option to remove your ECU and send it to APR Headquarters for installation.
    DirectPort Programming is another industry first brought to you by APR. DirectPort Programming is also referred to as
    "flashing" the ECU with the new operating software contained in APR's ECU Upgrade. No more soldering additional
    hardware to expensive and delicate factory electronics. DirectPort Programming facilitates ease of installation and
    offers new features to give you even more flexibility with your OEM ECU. DirectPort Programming is only available by
    bringing your car to an APR dealer or by mailing your ECU to APR directly.
    Demonstration Software
    All APR ECU Upgrades installed via Directport Programming are eligible for a 6 hour free trial. This means you can
    experience the performance of the APR ECU Upgrade for your vehicle at no cost to you for 6 hours of driving time! To
    receive a free trial, please inquire with your APR Dealer of choice.
    How to Purchase
    APR provides two easy and painless methods to purchase your ECU Upgrade. You may visit any APR Dealer
    for local installation while you wait or you can remove your ECU and send it directly to APR Headquarters for
    installation. Typically your ECU is returned the same day we receive it. For ECU removal instructions see our Customer
    Support page.
    If you're sending your ECU in to us, please print out and complete the order form below. Be sure to indicate which
    programs you would like to purchase, as well as the other information requested. For information on the program
    options, see above under the EMCS heading.
    APR ECU Modification Order Form (119K pdf)
    Security, Warranty and Money Back Guarantee
    All APR ECU Upgrades are fully encrypted to prevent theft of our valuable and proprietary coding information by lesser
    companies and to provide protection to our clients by keeping the upgrade undetectable to a dealership's VAG
    diagnostic tool.
    All APR ECU Upgrades include a limited lifetime warranty against defects in the software and to provide free updates
    and reflashes as they become available. Installation may be additional and is not included in the warranty.
    All APR ECU Upgrades offer a 30 day money back guarantee with no questions asked. If for any reason you are
    unhappy with your APR ECU Upgrade you may return the upgrade to your place of purchase for a full refund provided
    you are within a 30 day period from your time of initial purchase. Installation is not included in the guarantee and is
    at the discretion of the place of install.
    Video
    Video Here
    APR B8 A4 Wallpapers
    Each wallpaper is a high resolution 1920x1200 image. Click on the photo to get the full size image!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Ramon959
    Ramon959 New Member
    What if you dont have cruise control?
  3. scoTTy
    scoTTy Active Member
    1,962
    I'd guess you get it retro fitted first or by the company doing the remap. It's only around £150.
    Arin - As you've seen by my posts on Audiworld, I'm very keen on this after my past experience of APR on my TT. Do you have a UK price or will be getting it for the matching dollar price?
  4. scoTTy
    1,962
    I've just got a price from Awesome.
    Remap including all the above (lock out 4 program etc) for £624+VAT which is about £733.
    If only we could have it for the US price of £440 :jester:
  5. APR Jimbo
    APR Jimbo Total Engineered Performance
    The UK price is £499 + vat for single program and £99 + vat for the second. Our current offer is buy the first and get the second free or buy 2 programs and get the fully loaded ECU upgrade for free. However, if they are offering a fully loaded upgrage for the price of one program, we should be able to offer the same. We would need to check ECU numbers of your vehicle as its a new model and may have numerous part numbers that have not yet been covered. Hope this helps!
