Apexi Filter's - got a 2nd chance on eBay for a pair I only need one...
Maz Dec 12, 2011
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Hi guys, just checking if any of you wanted a decent filter at a good price?
    The auction was for a pair but I only need one of them.
    According to the seller he has four so as the second highest bidder I've got first dibs on the second pair.
    eBay - The UK's Online Marketplace
    Just need someone to go halves with me
    Part Number 500-A021
    Power Intake - Universal Filter (Replacement Filter), OD- 160mm, ID- 85mm APEX Integration
    They look legit to me and for £27.50 each worth a go me thinks.
    Let me know guys
    Thanks.
  2. <tuffty/>
    21,672
    4,101
    Look a bit small for an S3... do you know if they are 80mm openings for S3 MAF's?
  3. Maz
    1,002
    10
    ...copied from Apexi website link: Inner Diameter (filter base opening)= 85mm (3.35 in)
    What do you think Tuffty? I'm thinking of using one of these with a badger V2 tip at some point???
  4. <tuffty/>
    21,672
    4,101
    85mm is bigger than the MAF IIRC... the JR's Bill normally sells for S3's are 80mm...
    Whats the diameter and depth of the filter? the surface area of the filter if too small will restrict the B5 TIP's ability for total flow tbh...
    Bear in mind I have seen 10g/s increase on a Forge TIP going from a CDA to a JR and that Apexi doesn't look that much bigger than the one thats in the CDA :(
  5. Maz
    1,002
    10
    Appreciate your help, if it's no good no drama, just wanted to see if it was possible.
    Air Filter Dimensions:
    Outer Diameter (filter)= 160mm (6.30 in)
    Length (filter)= 120mm (4.72 in)
  6. <tuffty/>
    21,672
    4,101
    No probs... for reference, the JR filter (FR-08001) is 175mm o/d bottom x 172mm long x 140mm o/d top and is an 80mm opening...
  7. Logic_Dan87
    Logic_Dan87 Member
    46
    Iv got one off these filters, Was thinking to fit it on my s3 but was not to sure As it looks a little it small, Be carefull there a lot off fakes on ebay..
    Do your research and your get a real one ;)
  8. Logic_Dan87
    Logic_Dan87 Member
    46
  9. superkarl
    superkarl MAN OF STEEL
    9,569
    2,464
    how on earth would that filter attatch to the maf?
    il stick to jetex
  10. Maz
    1,002
    10
    Yeah, thanks for the link, read up about spotting fakes on seatcupra.net. That's where I first saw the same Apexi filter fitted to LCR's so thought it would work with an S3.
    I guess the MAF is different on the LCR, anyone know for sure?
  11. superkarl
    9,569
    2,464
    maf is the same.
    i wonder if the screw holes on the maf will line up with that on the filter.
    you have got a deal though at £27 each
  12. Maz
    1,002
    10
  13. <tuffty/>
    21,672
    4,101
    Personally I would just buy the Jetex... buy once, buy right....
  14. Maz
    1,002
    10
    I agree, I would have bought the Jetex months ago ...if only it was red.
    ...call me a tart if you want but I dont want any blue in my bay.
  15. <tuffty/>
    21,672
    4,101
  16. Maz
    1,002
    10
    Thank's for that Tuffty, just had a look Bill's section and I like the look of that induction kit package.
    Do you know if the gains are the same with the BMC and Jetex?
  17. <tuffty/>
    21,672
    4,101
    Not tested that I know of but if Bill thought for one minute they were not any good he wouldn't sell them :)
  18. superkarl
    9,569
    2,464
    their surface area looks a little smaller than the jetex. but theyre no where near as small as the apexi
  19. Jason.s
    Jason.s Active Member
    2,879
    348
    Apexi filters are one of the best. They look small but then you look at high power jap(that dont run custom TIPs) cars and they run them. About half the size of the Jetex. My mate has one on his 360bhp S14a track car. Flow is good and filtration is good.
