AP coilovers vs H&R 50mm springs - pics & review
smurfworth Aug 29, 2013
  1. smurfworth
    smurfworth Well-Known Member Audi S3
    1,949
    548
    Considering i struggled to find pics when i was looking for both setups heres a few
    H&R:
    Very comfortable and handle very well for just a set of springs
    Become bouncy after a while due to standard dampers not being adequate which becomes annoying
    Go low enough to scrape the undertray
    Wasn't low enough for my liking, i prefer a tight gap oooooerrrrrr missus
    AP coilovers:
    Harder than H&R springs but somehow comfier
    Dont bounce half as much as H&R springs did
    Go low enough for my liking even though they are wound all the way down, possibly has a little more to settle still though as these were fitted 5 days before these pictures
    Definitely should have ordered the AP coilovers instead of the springs but i was afraid of coilovers due to ruining my last car with JOM coilovers, they are awful.
    Definitely recommend the AP's, my advice would be don't be cheap on suspension like i did with my last car on JOM's, buy decent gear and you'll be happy, i certainly am with these AP's.
    V6 Quatt and Hoesty like this.
  2. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,298
    403
    I prefer the 50mm lower looks smart, mines like a 4x4 compared lol
  3. smurfworth
    1,949
    548
  4. LEE69
    2,298
    403
  5. smurfworth
    1,949
    548
    Haha yea, thats based on the 8L platform, which you cant get as low as the 8P because theres too much stuff that hangs off the bottom, been there done that lol
    The 8P can go stupidly low before you start scraping stuff.
    Mind you, i dont have an undertray anymore which probably helps
  6. LEE69
    2,298
    403
    Ahh right all new to the 8P was wondering if and how much i can lower by 50mm seems good, not after springs at the mo, too many other things i need lol
  7. smurfworth
    1,949
    548
    updated pic:
  8. (Dan Crook)
    (Dan Crook) Member
    87
    I have got the H&R Kit on mine too, I love the difference it made over stock but for me its still not low enough and doesn't feel as nailed down as I would like it too.. I will fit the Poly Bush kit and hope it feels better if not I will be getting AP's too! Attached some pics of how it looks on the H&R's now..
  9. Dubjam
    Dubjam a bullet with butterfly wings Team Ibis VCDS Map User Audi A3 Black Edition
    485
    132
    43
    Thanks for taking the time to post some photos, but attaachments dont seem to work
    I would say get some proper coilovers if you want your car to handle properly, potentially slightly thicker roll bars, anti lift kit etc. Putting £300 coilovers on your car will make it rock hard, and you might think because of this, your handling is better, but i bet my life on it wont be! low dosent always mean better, if you drop your car past its points of design balance, then you will in essence make it worse, and a good alignment set up is worth its weight in gold.
  10. Mujnu
    Mujnu Active Member
    513
    74
    I was looking at h&r sprigs for my SE. Would you guys advise me to change the shocks or will they be okay?
  11. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    633
    108
    43
    I'm on h&r 50mm and now fed up of hitting the speed bumps in London. Thinking of going with Eibach 30mm - I'm on Sline shocks ... Thoughts? Don't want the expense of decent coilovers.
  12. DPM
    DPM Site Sponsor Site Sponsor
    5,057
    220
    How many miles have your shocks covered?
    Damian @ DPM Performance
  13. DPM
    5,057
    220
    The EIbach Pro springs will give you more of a subtle drop and a lot more practical, should work well on the S-line dampers depending on mileage covered.
  14. downtothebone
    633
    108
    43
    23000 miles on 2011 plate ...
  15. Mujnu
    Mujnu Active Member
    513
    74
    125,000 miles. also would 2.0tdi s line shocks be a direct fit onto my 1.9tdi? Both 8P
  16. DPM
    5,057
    220
    You'd need to check what strut size the 1.9TDI had and make sure it was the same as the shocks from the 2.0TDI.
  17. Mujnu
    Mujnu Active Member
    513
    74
    Ok thanks that's helpful. Would you advise against getting used shocks?
  18. DPM
    5,057
    220
    Depends on the condition and mileage really. Personally I'd always go new if possible.
  19. Mujnu
    Mujnu Active Member
    513
    74
    Ok thanks a lot Damian.
