Anyway of finding out whether my A3 TDI's Remapped via Vagcom ?
kaz219 Dec 3, 2008
  1. kaz219
    kaz219 Active Member
    1,808
    As above.
    I wanted to make sure its not remapped before i spend money on a new map.
    I really dont want to be paying £50 for a RR so was wondering whether i could find out through vagcom.
    It kind of surprised me how it done against my mates accord type r so thats why im asking :D
  2. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Well you could do a datalog of the MAF readings, a chipped one should read about 1240.
    Paul
  3. kaz219
    1,808
    Thanks for that.
    But how would i do that ?
    Not had my vagcom long so limited on what i can do with it :D
  4. kaz219
    1,808
  5. Gti Jazz Blue
    1,655
    Yes that is the basics, you need to find the MAF data block on the 2.0 TDi.
    The last set that I did on my 2.0TDi (BKD) had data block groups 002, 010 and 011.
    The MAF reading is on block 010.
    Regards,
    Paul
  6. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    wht ws the result against the type r?
  7. kaz219
    1,808
    Cheers guys..il do it over the weekend and post the results :D
    Stuck side by side with the ATR but the ATR is a bit neglected and doesnt go into fifth properly. And driver wasnt too good (IMO) but nevertheless, My A3 TDI was side by side :D
    Just hope its not remaped already :D
    Ill get results up soon.
    Thanks Paul for the how to!
  8. kaz219
    1,808
    EDIT: Gona print screen it!
    Got the VAGCOM Measure block readings and i just floored it from first to fourth where i lifted off. I then wanted to do third gear - low rpm to high rpm but never got the chance as the traffic really built up.
    But with regards to paul saying a chipped mass reading should be around 1240ish, Mine does get to 1235. Or are these results too innacurate and do i need to find a long road go from high to low in third gear?
  9. kaz219
    1,808
