Anyone with xenons changed sidelight bulbs?
latta1989 Jan 13, 2010
  1. latta1989
    latta1989 Member
    147
    fitting xenons an wonderin if i should put diff sidelight bulbs in?
    iv seen led ones also just blueish ones or super bright white.
    can anyone giv me an idea of a good set to go for??
  2. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    there,s a thread on this somewhere , do a search if not someone will put a link soon enough
  3. Mick a3
    Mick a3 Mellow Yellow
    266
  4. latta1989
    latta1989 Member
    147
    cheers
    they say not suitable for after 2005 tho
    i hav 2006 :/
  5. niftyandy
    niftyandy Member
    100
    A bit of a silly question maybe but how do you change A4 sidelight bulbs? Ive taken my headlamp unit out but cant see how to get to either the high beam bulb or the sidelight bulb!! Do yoiu have to take the dark plastic shroud off the unit somehow as it seems to be fixed on with 6 clips?
    Any info would be great
  6. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    when i changed mine, i loosened the headlamps to gain a bit more room then had to move the retainer/clip to one side on the back and the black cover on the back just pulled off. Was then able to access all bulbs to change. Ended up changing all to get rid of the amber ligh bulbs to super white. Also changed the idicator bulbs to the 'soap bubble' diadem bulbs, looks ace now.
