Anyone with an 8P 1.6 FSI on here?
JohnE Jul 24, 2013
  1. JohnE
    JohnE 2005 A3 Sport 1.6 FSI
    415
    40
    Care to reply or PM? Would like to compare notes on a few faults with mine.
  2. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    just say them on here, because then non 1.6 owners will also learn! :)
    JJ.
  3. JohnE
    415
    40
    Tried that, no response so now trying a different tack, like altering the words in a google search :)
  4. Boydie
    Boydie Boycie VCDS Map User
    3,247
    359
    If no one replied in an open thread, what makes you think they will go to the hassle of creating a new PM.
    What faults are you experiencing?
    JamesS4cab likes this.
  5. stuartm
    stuartm VCDS Map User,
    260
    22
    I have a 1.6fsi mate
    what faults do you have?
  6. JohnE
    415
    40
    Faults -
    Clutch judder esp in reverse and esp when cold.
    Weird jerky throttle response on a constant throttle - eg constant 35mph in 4th gear or in slow moving traffic - it's impossible to make smooth progress in a traffic jam in 1st/2nd gear without slipping the clutch.
    Intermittent minor misfire at idle - can't see any pattern - happens hot/cold long/short trips all weathers.
    Car has done 84K with FSH - has had the cam chain changed under warranty when younger (I assume for the rattle of death - which it still does very occasionally, again with no apparent pattern).
  7. JohnE
    415
    40
    This :happy:
  8. JamesS4cab
    JamesS4cab Well-Known Member
    1,189
    94
    Isn't the biggest problem the fact that it feels like there isnt a turbo fitted??................... Thats certainly the case with my wifes one.
  9. JohnE
    415
    40
    It is gutless, but not as gutless as that - I'm fairly sure we established your wife's 1.6 is the 8v not the FSI, since it has a cambelt.
  10. Mike071288
    Mike071288 Active Member
    287
    26
    -Clutch judder happens on mine too, not really a fault more of a characteristic, not too bothered about it, just got to be abit more carefull when its cold.
    - not sure about making smooth progress issue, maybe try cleaning the throttle body.
    - misfire at idle, happens on mine to, but is more noticable when holding the car on the foot brake. probably something i should look into.
    Hope this puts your mind at ease.
    JohnE likes this.
  11. JamesS4cab
    1,189
    94
    FM you have a good memory!! Maybe i just need to shed a few lbs to make it go faster. Or if anyone is selling 8 valves, then do please let me know as we are thinking of selling up.
  12. stuartm
    260
    22
    i get clutch judder too in mine, mostly in reverse though, won't bother about it till it starts slipping in other gears lol
    as for the jerky throttle response, could be a problem with your coil packs but don't quote me on that, as I've changes mine twice, mine is an 05 plate with 61k on the clock.
    JohnE likes this.
  13. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    73
    I have a 1.6FSI
    The judder in reverse also happens with mine but not an issue TBH
    Slow traffic at 5-10MPH is a PITA 1st gear power surges so not smooth and 2nd gear riding the clutch can't be good.
    Mine is rapid though ;)
    JohnE likes this.
  14. stuartm
    260
    22
    that 1st gear power surge is a killer glad its not just mine that does it lol.
    How did you manage to get yours rapid lol
    mine feels a bit sluggish these days
    JohnE likes this.
  15. JohnE
    415
    40
    1.6 FSI brothers and sisters - thanks a million. Glad to know it's not just mine or my **** driving. That said, having had a Polo, bay window type 2, 1.8 passat and 2.8 VR6 Passat, this has by far the best seats and by far the worst everything else
    [Edit] Actually the climate control is wonderful - the type 2 had no heating.
  16. Boydie
    3,247
    359
    Check your spark plugs or better yet, for peace of mind, change them.
    If you are still experiencing problems with misfires, change the coil packs.
    Clutch - do these come with a dual mass flywheel? Could be on its way out or the release bearing causing the judder.
    Throttle body, remove and clean.
  17. JohnE
    415
    40
    Thanks Boydie - I changed the plugs and it made no difference - considering how common the misfire is (on other's cars) and how it doesn't seem to affect anything else I'm not mad keen to shell out for a set of coil packs.
    I was wondering if this model has DMF - but again, everyone else's seems as bad so given the replacement cost (esp if it is DMF), the same applies.
    I will do the throttle body though - that has to be worth a go.
    Cheers.
  18. CraigWonn8P
    CraigWonn8P New Member
    15
    Guilt 1.6Fsi owner.
    1st gear power surge is a nightmare. I live in city centre Edinburgh and town driving is terrible.
    Misfiring is the coilpack- changed mine last year and all good.
    I currently have ESP/ABS lights on when going past 50-60MPH - I believe this is to do with the speed sensor in a front wheel bearing although will need to look out.
