Anyone with a Forge FMIC? Help needed!
JoeD Jul 24, 2012
  1. JoeD
    JoeD Member
    537
    10
    I've got one ready to fit, but It never came with all the piping or clamps. Not having too much of a clue about these I need to get the piping sorted so I can fit it. Not had much luck so far trying to find what size pipes I need, and Forge have been w4nkers, when I asked what piping is required to fit it. So I'm now at the stage where the my cars sitting in a garage waiting to fit the FMIC, but until I can find out what piping I need to order, I'm car-less and can't go any further.
    I was going to order this lot, but I'm not certain that this is what I need... Obviously if it's not, I don't want to waste £50, so if anyone know's, and could save me the hastle of ordering the wrong stuff, I'd really appreciate it.
    Would really appreciate ANY help guys as I just want to get this sroted and fitted to I can get back to driving it.:racer:
    Thanks.:)
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
  3. niallh
    niallh Member VCDS Map User
    213
  4. aragorn
    18,491
    855
    i'd try to stick to 60mm pipes as much as possible if you can.
  5. superkarl
    superkarl MAN OF STEEL
    9,554
    2,453
    63mm here.
    think the outlets on the forge core are 60mm. you'd want that as a minimum really
  6. Colly
    Colly Member
    282
    This is what mine came with if it helps any
  7. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    1x 63mm 90 (for charge pipe)
    1x 63mm coupler onto tb
    2x 63mm alloy 45s
    2x 63mm alloys 90s
  8. JoeD
    JoeD Member
    537
    10
    Cheers guys, think I'm getting there:happy:
    Cheers for the pic Colly, do you know what size (Length/width) those pipes are? I have a few pipes with me, with Forge markings on them, but not 100% sure if it's come with all of the above like yours.
    But to be safe, with the Forge's 60mm core, if I order the following to be safe,
    1x 60mm 90°
    1x 60mm coupler onto tb
    2x 60mm alloy 45°
    2x 60mm alloys 90°
    I should be able to fit it?
    Cheers guys!!
  9. Hammy999
    Hammy999 Member
    175
    Colly when are you getting your FMIC fitted?
