Anyone who has fitted LCR top mounts?????
IOM-S3 Mar 29, 2011
  1. IOM-S3
    IOM-S3 Member
    119
    Hey guys, still trying to get more information on what my mystery knock is. so far i have replaced:
    New r32 anti roll bar and bushes
    2x new drop links
    2x new balljoints
    2x powerflex front arm bushes
    2x rear solid bushes for bottom arms
    Leon Cupra R top mounts and bearings
    Powerflex dog bone mount bush
    still got track rod ends and steering rack bush to fit but im coming to a loose end now, have checked the steering rack bolts, subframe bolts etc.
    only issue i have is that the Leon cupra R top mounts had alot more play in them than the standard ones i took off, has anyone else had issue with the LCR top mounts,
    In need of desperate help now as thinking i may sell if i dont cure this annoying knock :(
    thanks again
    Lee
  2. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    When do you get the knock mate... Are you from the Isle of Man ?
  3. mrj0ey
    mrj0ey Member
    105
    I recently changed all of the above (except top mounts) and got a phantom knock.
    I tried everything, finally got it sorted today.....before i had torqued everything up on axle stands, today i used some ramps and loosened off the rear wishbone bush nuts, then torqued them back up under load....knock has gone. Apparently all the wishbone nuts should be done up under load.....worth a try.
  4. IOM-S3
    IOM-S3 Member
    119
    cheers for the reply guys, will try that, i am from the isle of man mate :)
    knocking is when going over bumps, uneven road surfaces
  5. cecilthesausage
    933
    I thought so I used to live there many years ago
  6. IOM-S3
    IOM-S3 Member
    119
    ahhh cool mate, where abouts did you live? did you like it over here?
  7. cecilthesausage
    933
    I lived in Douglas lived there for 12 years my sister still lives there
  8. IOM-S3
    IOM-S3 Member
    119
    Ace :) small island as well i probably know them haha
