Anyone usinin W/M injection??
Biglockie Mar 6, 2008
  1. Biglockie
    Biglockie Aye you know it makes sense
    1,032
  2. celsisone
    celsisone Member
    31
    I run water injection on an S4. but use an aquamist kit. works very well..
  3. macca
    macca Member
    525
    i'm going to be using aquamist with my big turbo when installed shortly, aquamist are quite near me and the fact that a lot of the cars at the brighton speed trials use them is good enough for me.
  4. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    I used to use the ERL Aquamist kit in my S2. To be honest I would only use it once intercooling options have run out. Since the fitment of a full width Pace intercooler the ACT's are never high enough for the Aquamist kit to kick in.
  5. Biglockie
    1,032
    The intercooler I'm looing at needs to fit behind the bumper, dont want to butcher the bumber to fit a u IC, so lookin at other options
  6. celsisone
    celsisone Member
    31
    Yes, only fitted my kit because I had upgraded to RS4 IC's on my S4 and was a lot better, But the intake temp was still getting to high. The Aquamist 2D kit solved this problem. But then fitted a FMIC anyway.
  7. aragorn
    18,608
    871
    imo the requirement for water injection means your intercooling isnt up to the job or your turbos running way out of its efficiency band.
    I would never actually plan to run an engine on it, you should be looking at FMIC and Chargecooling solutions first, perhaps a decent sized FMIC and a charge cooler might be enough, but if your seriously expecting to need it then you have something wrong with your spec imo
  8. Biglockie
    1,032
    I'll look into the FMIC and charge cooler option too.
