anyone used these calipers?
Discussion in 'A3/S3 Forum (8L Chassis)' started by dantheman1986, Jun 11, 2008.
  1. dantheman1986
    dantheman1986 Member
    Mar 27, 2006
    262
  2. Advert Guest Advertisement
  3. grathies
    grathies More Points Than Portsmouth FC
    Dec 15, 2004
    1,343
    Id want to hear from someones whos fitted them
    Main concerns would be do Brembro compatible pads fit the units, how easy is it going to be to get carriers or how much will you spend getting some fabricated and then how well will they work. Need to be careful with caliper size as well, always remember you may have clearance issues, especially if they mount different. I know the Brembros fitted to Fiats were often bought by VAG boys for fitting to Golfs as a cheaper option and they were a total nightmare to fit and working properly
    Brakes and Tyres are two main areas Id NEVER look for a cheaper unproved option on, doenst matter how fast you can go if you cant stop
  4. grathies
    Dec 15, 2004
    1,343
    Oh and obvioulsy dependant on how big they actually are, they may dimish what little pedal feel there already is, so may need to fit a bigger master-cylinder too
  5. dantheman1986
    Mar 27, 2006
    262
    ok good points, i just thought they look identicle to the ones from the cupra r's so maybe could used the same mounting brackets as them?
