Anyone use these coil packs?
Andrew@A.L.D May 26, 2010
  1. Andrew@A.L.D
    3,877
    617
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    arnt they oem? saying that i have hitachi on mine
  3. <tuffty/>
    20,992
    3,760
    OEM all day long tbh bud....
    Should be noted that coil pack failure is accelerated by incorrect plug gaps... was fitting a Leon with a hybrid K03 and the packs started failing.... checked the plugs after replacing a couple of packs and the gaps were over 1mm!!
    0.7mm for mapped engines
  4. Andrew@A.L.D
    3,877
    617
    Ok i also need CTS and Pre cat O2 sensor, im i best getting OEM with these?
  5. <tuffty/>
    20,992
    3,760
    I bought both a CTS and pre-cat (wideband) lambda from GSF... lambda was a Bosch part so thats fine...
    Its a funny old game but some parts are better from Audi, others can be sourced form GSF (and others)
  6. Andrew@A.L.D
    3,877
    617
  7. finesse
    finesse Active Member
    2,805
    get it direct from audi
  8. Andrew@A.L.D
    3,877
    617
    Done a quick search and found for a bolt down coil pack for a APY S3 part number is M A06B 905 115 E
    Is that right?
    Do you have the part numbers for the CTS and O2 sensor from GSF Tuffty?
