asked the same question not along ago, got same answer.....anyoneeeeeeee???
There is no stock from Bilstein, i know because i tried to buy them from all over the internet!.
I do however have B14's and will have them installed next week.
I wouldn't go for b8s
I was worried that b14 coil overs would be too stiff but if anything they are only slightly stiffer than stock!
B8s are probably going to be indent ideal to the stock Sachs units!
Well I will ask Awesome to supply the exact information on the shocks and report back. Then we will all know.
Because as I explained the b14 shocks which are stiffer then b8s are only slightl stiffer than the standard suspension.why not B8 shocks? please explain.
So if you install b8 you will not likely notice any difference, the biggest difference will be from the lowering alone.
Also with the b14 (and b16) you can adjust the ride height, it can be as high as stock or dropped super low.
With b8 and springs it's a fixed ride height.
so does that mean that the B8s won't solve, the rebound issues that others have talked about on the forum which leads to the unstable feeling you get on English B-roads at speed ?
