anyone REALLY technical out there?
Administrators Jan 7, 2003
  1. Administrators
    Administrators Administrator Staff Member Administrator Audi A4 TDi
    3,976
    588
  2. S3Bangs
    S3Bangs Member
    72
    Depends on what you mean!! What I do is pretty technical. And it is the building trade I think:p /ubbthreads/images/graemlins/grin.gif
  3. toasty
    toasty Member
    52
    I assume you mean the motor-trade?
    I can do technical IT type stuff, but only really know car electrics as Joshie will no doubt testify /ubbthreads/images/graemlins/grin.gif
  4. Administrators
    3,976
    588
  5. richyboy
    richyboy Member
    41
    I was until 1999, then got fed up with the trade, /ubbthreads/images/graemlins/smile.gif city+guilds etc 15 years all in
  6. Joshie
    Joshie Member
    71
    [ QUOTE ]
    [/ QUOTE ]
    .Yes Dan - saved me on a couple of occasions, once when I needed a solution to the electronic switches when I uprated the interior of my S4 to post facelift and the other to get the lights on my aircon unit to work
    Just as I was getting suicidal too /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
    Thanks mate /ubbthreads/images/graemlins/cool.gif
  7. toasty
    toasty Member
    52
    John,
    you've got us all intruiged now.
    What's the question?
    -Dan
  8. Administrators
    3,976
    588
    [ QUOTE ]
    [/ QUOTE ]
    yeah me too, I got out a lot longer ago than that to be honest,
    when it all went on to bonus and quality of work became less important I left it.
    Main Dealer stuff is very humdrum!
  9. Administrators
    3,976
    588
    [ QUOTE ]
    John,
    -Dan
    [/ QUOTE ]
    Nothing really, that was the question!
    Just wondering who else there got there C&G and went through those early very badly paid years! /ubbthreads/images/graemlins/smile.gif
  10. Mutley
    Mutley Member
    67
    I'm not in the trade but I think I'm technical. I designed and built a mapped ignition module to replace the centrifugal advance in a Mk1 Golf GTi distributor. The springs get weak and advance the ignition too fast. A common compensation for this is to set the static advance to less - which screws up the overall advance curve - a common fault for lack of power in these superb engines. I measured the advance by spinning the distributor whilst measuring RPM with a hall-effect rev counter which I designed and built also, then measured the angle. Vacuum advance was taken care of using the original diaphram unit and a grey-code slider. Once that was done I programmed an EPROM with the parameters and designed appropriate voltage regulation circuitry. I could then swap EPROMS to experiment away from the 'factory' advance curve. This was back in 1984 but have done an electronics engineering degree since then. I have always applied what I know to electronic and mechanical engineering in vehicles.
    Christ I sound like a right boff /ubbthreads/images/graemlins/confused.gif having read that back - I guess I'm saying I know first principles mechanically and electrically so I'll always try and help from a theory point of view.
    Jon
  11. Administrators
    3,976
    588
    [ QUOTE ]
    Jon
    [/ QUOTE ]
    cool! I was just looking at trying to start a serie of quite technical posts, want to start at the basics and try to help everyone understand a little more, plus I'm always keen to find out stuff I don't know, actually I'm really bad like that, there'll be something come up that intrigues me... I have to write it down so I remember to research it later, otherwise next time it'll bug me I forgot to find out how it worked!
  12. audi_girl
    audi_girl Active Member
    1,038
    That sounds like a plan - I want to know more about my car works without having to trawl loads of sites..
  13. Administrators
    3,976
    588
    [ QUOTE ]
    [/ QUOTE ]
    /ubbthreads/images/graemlins/laugh.gif
  14. richyboy
    richyboy Member
    41
    [ QUOTE ]
    Jon
    [/ QUOTE ] AH but have you ever fitted a clutch on a Triumph Toledo /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/shocked.gif
  15. richyboy
    richyboy Member
    41
    [ QUOTE ]
    [/ QUOTE ] I got fed up with the main dealer attitude of Bonus, Bonus, Bonus. And small garage attitude of Low pay, Low pay Low Pay. So now I drive a train /ubbthreads/images/graemlins/blush.gif
  16. Mutley
    Mutley Member
    67
    This is a good site to start with - http://www.audi-sport.net/ubbthreads/showflat.php?Cat=&Board=generalchat&Number=1303&page=0&view=collapsed&sb=5&o=&fpart=1
    It covers several aspects of the S3, namely 4cyl engine characteristics, 5V per cylinder, turbocharger (yours is a K04 I think), intercooler, Haldex centre 'differential', traction control with conventional diffs / ABS - Audi call this EDL, ESP, ABS, understeer and oversteer, tyre slip angles etc.
    Maybe there should be a poll to discover which parts of their cars people want to know most about?
    Jon
  17. Mutley
    Mutley Member
    67
    No! - never had that pleasure... I've de coked a 2L Pinto - and I'll never rest the drill on the bench again while using a flexible drive with a rotary wire brush which jams solid in a port... The 240V drill took off and wrapped itself around the power cord and me at the same time /ubbthreads/images/graemlins/grin.gif . I've changed various bearings in gear boxes and diffs where the preload is critical, burnt the skin off my hands doing a ring gear, dropped an eccentric valve clearance lock nut down an oil drain hole (gf at the time said 'just turn the engine upside down - it will come out... my comments nearly caused instant divorce), and gave a Capri 5 reverse gears and 1 forward (fitted a diff with the crown wheel on the wrong side...)
    Bit scared of the S8 though - have only had the engine covers, air intake and spark plugs out - there don't seem to be many owners on forums who want to play (or are interested)
    Jon
  18. Well never worked in the trade etc.
    I did build this from scratch a few years ago
    (assuming the piccys there!), hand built chassis etc, powered by GPZ1100 (bored to 1380).
    Damn good fun to drive, managed a few FTD's in it and a fair few class wins.
  19. AndyC
    AndyC Moderator Staff Member Moderator
    719
    I would be more than happy to help with technical stuff...
    I am in the trade and often scan the boards trying to help... its my hobby too... hense the time spent..
    I have worked on french german and Jap cars, from basic servicing to full engine rebuilds etc etc...
  20. Gambba
    Gambba Active Member
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    It's good to have you onboard then Andy. You've got a JR filter fited on your A4, are you not concerned about MAF issues?
  21. AndyC
    719
    not really... they are not oily mate.... not like K&N...
    been in for 10k miles and is fine..
    if it goes wrong you lot will be the first to know
  22. MisterD
    MisterD Member
    85
    [ QUOTE ]
    [/ QUOTE ]
    I have fitted a clutch on a Triumph Herald. Does this count?
  23. corradospy
    corradospy New Member
    I have conducted percussive maintenance on a variety of VAG products over a 15 year period. /ubbthreads/images/graemlins/goofy.gif
  24. Major_Ingram
    Major_Ingram New Member
    What the hell is percussive maintenence???
