Anyone managed to clean up their chrome window surrounds?
allyp Feb 17, 2011
  1. allyp
    allyp Member
    222
    As above tried everything in my cleaning kit but nothin will take the chrome/aluminium strips up,they still look misty,anyone used something they can recommend ,thanks
  2. a4 cabrio
    a4 cabrio Member
    135
    you talkin about the chrome/ally strips that run up the sides of the windscreen??? i would like to know how to clean them up as well
  3. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Ditto ! I did read somewhere that the wrong kind of screenwash can make them look corroded... mine look ok for while after I was them but they sooon go chalky/milky..... they are also very hard to remove to refurb I understand.
  4. allyp
    allyp Member
    222
    yeh thats right m8 just cant get them clean ,only one i found is something called quixx autoscratch remover searched it out on line but not sure if it will work
  5. hades-
    9,481
    646
    its the water that gets under thats why they go misty so im told
    thats why i never have chrome
  6. a4 cabrio
    a4 cabrio Member
    135
    i havent had the chance to give my car a good wash since i got it coz of this rubbish weather, but i have noticed the chrome strips could do with a polish, i think they will annoy me when i have spent a few hours doin the car and they are the only scruffy looking thing left lol
  7. allyp
    allyp Member
    222
    more the ones on the doortops and round the doors that are tarnished
  8. quattrojames
    14,050
    576
    I use AutoGlym Super Resin Polish. The result aren't instant, but if you do it weekly after a month or so you should notice a massive improvement.
  9. allyp
    allyp Member
    222
    ive tried meguiars chrome cleaner, clay ,superresin, rainex,brake cleaner,other scratch remover,g3 cutting compound nothing touched it ,there were lots more as well lol think ill order the quixx stuff to see as its doing my nut
  10. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    If theyve gone milky, the only option is to replace.I had a door trim go milky after 9 months and replaced under warranty....dealer stated that they are unrecoverable.Its water that gets under the plastic top coat.
  11. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    It's something you will have to live with once the chrome trim has sign's of water damage/ age and so it is very hard to reverse. I think it's the one thing that let's a car down, when we detail car's with chrome trim work we can't correct it 100%. I know of member's on this and other forums who have had the trim vinly wraped or painted black.
  12. allyp
    allyp Member
    222
    mmm,ok if the stuff i order works ill report back doesnt look good though
  13. vorsprung dork
    vorsprung dork Member
    256
    i use autosol metal polish available on ebay at about £3 a tube! takes a couple of aplications but worked a treat on my avant roof rails and chrome window surounds! (its got aloy oxide in it the hardest minaral on earth after dimonds!! how do you rate that for being a geek) so removes all that spunky tarnish look!
  14. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Could you use autosol for example or would this be a no go?
  15. allyp
    allyp Member
    222
    ive tried peek metal polish it wasnt any good maybe the autosol will work then,i was told maybe a jewellery cleaner might work as it has some cut in it?
  16. hades-
    9,481
    646
    wont get it off as its under the plastic finish
  17. allyp
    allyp Member
    222
    are you sure its coated m8?
  18. hades-
    9,481
    646
    yes its coated as stated from audi uk
  19. allyp
    allyp Member
    222
    Ok so nobody can fix this then?is that right replace or put up with it
  20. vorsprung dork
    256
    autosol! for £3 its worth a try mate it works for me! i was told that these parts were adnonised!!
  21. little ted
    little ted New Member
    have a look at these products they may help i used the hot chrome polish to get rid of water spots on the window trims but they came back so it may be worth sending them an email to find out what is the best to use.
    Products - Automotive aluminum and metal polish
  22. allyp
    allyp Member
    222
    Ok cheers vorsprung ill give it a go,and little ted ill email them cheers
  23. allyp
    allyp Member
    222
    emailed awaiting response
  24. benjie
    benjie Well-Known Member
    1,223
    304
    Autoglym bumper care (green stuff) gives a fairly good improvement, but it doesn't last very long.
  25. allyp
    allyp Member
    222
    Ok thanks m8
