anyone know what fault code 17966 is?
bouncer117 Nov 14, 2013
  1. bouncer117
    bouncer117 Member
    308
    as above does anyone have any idea what fault code 17966 is? as its not on wiki ross tech
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Got more details on it?
    Did you use VCDS to get the code?
  3. bouncer117
    bouncer117 Member
    308
    na just code reader
  4. ScottD3
    15,166
    1,126
  5. bouncer117
    bouncer117 Member
    308
    do I need vcds to do a tba?
  6. Bradderz_1988
    3,995
    262
    Yes you will need vcds/vagcom !!
  7. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,046
    790
    A quick google gives the following error. 17966 - Throttle Actuator (G186): Electrical Malfunction
  8. bouncer117
    bouncer117 Member
    308
    where would people recommend to get a cheap cable from? I bought 1 a while ago off ebay, but it doesn't fit (the 16 pin plug is too big). I already have the programme just the cable needed
  9. ScottD3
    15,166
    1,126
    I had the same issue but I trimmed the area around the port a little bit with a knife and its fine now.
  10. Bradderz_1988
    3,995
    262
    Yeah mines not the best fit either, will go in with a little wiggle though no need to trim anything !
  11. bouncer117
    bouncer117 Member
    308
    ill give it a go and see what happens. thanks
