anyone know the wheel bolt spec/dimensions?
jcb Oct 28, 2010
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    M12x1.25?
    what grade/tension?
    cheers
  2. aragorn
    17,806
    679
    They not M14?
    IIRC they're M14x1.5 with a radius seat.
    For the grade i'd be going as high as possible, probably 12.9.
  3. jcb
    4,132
    13
    cheers, anyone confirm?
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    Yep, M14 x 1.5 for Audi
  5. jcb
    4,132
    13
    cool, cheers.
    off to buy some studs and nuts!
  6. Foxmeister
    1,785
    Whats in the pipeline, custom hub/wheel mount that require these???
  7. jcb
    4,132
    13
    two sets of wheels with different offsets one with spacers one without. want to run some winter tyres and if I buy spacers and longer wheel bolts to accomodate I then still have to use different bolts to refit the others.
    sounds like ballache and a recipe for disaster when i lose some of the "not in use bolts" while they are off the car!
    also a hell of a lot easier to change wheels with studs than bolts.
    may even keep some tasty wheels for summer track use!
    have to do some bearings anyway shortly so makes sense to do them all at onmc
