Anyone know of any cheap Audi Breakers / garage in the Swansea/Port Talbot Area?
J
jonnycraig
Guest
My B5 probs are ongoing, usual thing cash is a very tight and things then gather up and fail all at once! I need my car to travel the 70 mile round trip to work every day. So any suggestions on the best way or order to get the following fixed, or do I put the money into a cheap runner with the risk of inheriting new probs.
  1. Last night ice has burst the radiator, hole must be too big for radweld to fix (not that I hold much hope in it anyway) thought I had enough antifreeze in there but obviously not!
  2. There is a water leak where coolant pipe comes from the top of the rad and enters the block between the injectors, gasket gone?
  3. Indicators do hazard lights up or down - Stalk or hazard switch
  4. Fanbelt is starting to fray so should I do timing belt, waterpump and thermostat too?
  5. 152000 miles on the clock, so timing belt due soon anyway? 160k is it?
  6. Oil temperature gage has never shown a reading is that dangerous?
  7. and finally.... water temperature usually displays about 60-70 degrees according to the gage and climate code 51 display trick (lazy/faulty thermostat?)
Thanks for reading my probs
Cheers Jonny
Hi mate, to be honest if apart from the faults you've mentioned and if the head gasket hasn't gone it's probably worth fixing, because as you say you will only end up buying a cheap run-around and inherit more problems. All the things you've listed shouldn't really come up to more than a couple of hundred quid and where are you going to get a decent car for that?? Entirely your choice but I would fix it if I was you. If the head gasket hasn't gone anyway.
I'm breaking a B5 at the moment, in the south Wales area, if you need parts cheap, I'm your man lol!
    Did you put radweld in to your rad? If not, please don't. But a new rad off ebay or if money is a bit tight, talk to a couple of the B5 lads thats breaking their motor.
    Thats possible the same thing as I just sold. Its plastic flange that splits. its bout £10-£15 off ebay or again, talk to one of the breakers and see they can supply you with the one off of theirs as a temp fix but I would deffo look in to a new one.
    They do what up and down? You indicate left and all indicator fault? Possible relay fault. Again Talk to a breakers and ask for the Hazard switch.
    I'll answer 4 and 5 here. Yes do it. Fan belt is every 60k or 4 years (I think) but its at 152k and no sign of replacement then do the two belts, waterpump, thermo and adjusters.
    Not really. Most cars don't have a oil temp.
    Could be thermo. get that replaced but if you order the part for fault #2, ask them to keep the coolant sensor in.
To get the real-time coolant temp it is code 49 on the climate control panel!
I replaced my thermostat the other day as I was also getting a low gauge temp (it has always sat bang on 90 degrees once warmed up) and this cured it totally.
A Genuine Audi 'stat cost less than 20 quid , so don't try and get a cheaper/pattern one, by all accounts they are crap!
Having said that, the thermostat I took out was also Genuine , and had 'only' lasted since Feb '09 and approx 40k miles!
Cheers for all the replies and advice guys, to top things off my battery died this morning and with no neighbours around to jump start me I had to ring the AA Grrr!!
Where abouts are you? PM me if you wanna give a bit more detail about what you have etc :)
