anyone know if
hades- Mar 19, 2013
  1. hades-
    9,482
    646
    this part nimber will work instead of this
    this was water damaged 8EO 907 279 C central electric modual
    should this work ? same number diffrent end letter 8EO 907 279 B
    pluged the B unit in and it keeps sidelights on when trying indercators it flashes the side lights fast
    no fault codes etc
    TIA
  2. archemist
    archemist Active Member VCDS Map User Team Brilliant Black Audi S3
    247
    31
    My car is an 02 but 03 model year and it has the 279c unit in it.
    The parts catalogue lists 279d thru g the difference being d isn't listed for DIS (but mines a C and DIS works!)
    [TABLE]
    [TR]
    [TD="bgcolor: #D7DBD3"][TABLE]
    [TR]
    [TD="align: center"]1[/TD]
    [TD]8E0907279D[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]onboard supply perform. module
    / [TABLE]
    [TR]
    [TD="align: center"](1)[/TD]
    [TD]8E0907279E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"]onboard supply perform. module / for vehicles with driver informationssystem -fis- / F >> 8E-3-191 155*
    / AVANT [TABLE]
    [TR]
    [TD]8E0907279E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]onboard supply perform. module / for vehicles with driver informationssystem -fis- / F >> 8E-3-191 155*
    / sedan [TABLE]
    [TR]
    [TD]8E0907279E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"]onboard supply perform. module / for models with day driving headlights / F >> 8E-3-191 155*
    / sedan [TABLE]
    [TR]
    [TD]8E0907279E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]onboard supply perform. module / for vehicles with driver informationssystem -fis- / F 8E-3-191 156>>*
    / [TABLE]
    [TR]
    [TD]8E0907279E[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"]onboard supply perform. module / for models with day driving headlights / F 8E-3-191 156>>*
    / PR-8K1,9C6 [TABLE]
    [TR]
    [TD]8E0907279F[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]onboard supply perform. module / for models with automatic day driving headlights / F >> 8E-4-110 000
    / PR-8K3,8K7 [TABLE]
    [TR]
    [TD]8E0907279F[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"]onboard supply perform. module / for models with automatic day driving headlights / F 8E-4-110 001>>*
    / PR-8K7 [TABLE]
    [TR]
    [TD]8E0907279G[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    onboard supply perform. module / for models with automatic day driving headlights / F 8E-4-110 001>>* / relay plate / PR-8K3
    [/TD]
    [/TR]
    [/TABLE]
    A 'B' unit should preface a C and usually the later units are backwards compatible.
    Have you looked at adaptation and coding - as the unit you are putting in could be coded for lights, etc.
    Ross-tech (b6):
    Audi A4 (8E) Central Electronics (8E2/8E5) - Ross-Tech Wiki
    though the B7 has additional codes:
    Audi A4 (8E) Central Electronics (8EC/8ED) - Ross-Tech Wiki
    cheers
    And
  3. hades-
    9,482
    646
    yes iv coded it
    to what it was before
