Anyone know how to open the headlights?
Westy Jun 28, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    I had my passenger headlight out last week when I was fitting my FMIC and I wanted to get to the bottom of the light bouncing around every time I hit a bump.
    It turns out that the little white stalk from the adjuster motor had come out of the holder on the back of the bulb fitting plate and the whole thing was swinging about like a **** in a bucket!
    Anywat I tried to open the headlight for easy access and couldn't so I tried to wiggle the motor arm into the holder and ended up breaking the holder :banghead:
    I also need a new holder if anyone has a spare headlight unit kicking around PM me.
    Westy
  2. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    you have to gently heat them in the oven and then you can prize them apart
  3. Westy
    17,443
    1,105
    :wtf:
    Is there a recipe in Jamie Olivers latest book :)
  4. Dane
    4,086
    182
    honest guv,
    they are sealed, you need to warm the sealant to prize the lens away from the rear.
    a heat gun would do the same
  5. Westy
    17,443
    1,105
    What about resealing them afterwards?
  6. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    does the hot water trick work on these or oven best idea its true westy head lights in the oven.
    would be a good one if mrs asks whats for tea erm ......... head light lol
  7. Syvo
    1,338
    22
    heat them back up when put together as the seal is basically glue so when it goes cold it sets heat it up unsets
  8. Westy
    17,443
    1,105
    Does red wine go better with headlights or white ;)
  9. Dane
    4,086
    182
    White for sure, as syvo says same process in reverse to seal them, but you may want to seal them again just in case.
  10. Syvo
    1,338
    22
    lmao white as dane says
