Yep, once the egr is off there's loads of room to work under the turbo... You can get propper egt bungs and have them welded onto a plate, reason is the thread is conical and will seal properly, only snag is the plate usually warps from heat while you weld it. Best to have it bolted on a piece of metal to keep it straight...
