Anyone in Portsmouth Area with VCDS?
bobberuk Nov 30, 2013
  1. bobberuk
    bobberuk New Member
    I have a really bad fuel consumption issue, it's costing me a fortune in diesel. I bought a cheap hand held code reader off eBay but its reporting no error codes... although I'm not convinced it's any good.
    Anyone local to me (Fareham/Portsmouth) got a VCDS they could help me out with?
    Also my temp never goes above 75, no matter how long the car has been running or whatever kind of driving.
    Any help anyone can offer much appreciated!
    Bob
  2. Prawn
    11,500
    3,411
    I'm reasonably local in Basingstoke mate, but I'll be honest I don't know anything about using VAGCOM on a tdi!
    Poor fuel consumption combined with low running temp would suggest the stat is stuck open, so it's never heating up and remaining on a cold start state, which typically will use more fuel.
  3. bobberuk
    bobberuk New Member
    Thanks for that, just been down to Euro Car Parts and bought a new stat which i'll put in tomorrow. I have however made another interesting discovery...
    The bolts that should secure the EGR valve (to the right of the EGR as you look at it standing in front of the engine) are missing. I thought it was leaking oil because a gasket had blown, but on closer inspection there is no gasket, hence it's not sealed! Would this perhaps also have some kind of effect on the heavy fuel consumption?
    Frustratingly I've bought a new set of gaskets and some EGR cleaner and was going to whip it off and clean it up tomorrow, but without the right bolts, I guess I need to wait and order some new ones up....!!
    I will also be on the phone to the garage who did some work on my car a couple of months ago. They had the head off, so assume they will have also had the EGR off.... looks like they forgot the bolts and gaskets!
    GRRRR!!!!!
    Bob
  4. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    maybe the coolant temperature sender aswell, this will cause odd temp readings and can strangly cause alot of weird stuff to happen on the 1.8t's? so may be similar on the diesels...
  5. bobberuk
    bobberuk New Member
    I seem to remember i've changed that before already, but might change it again anyway, not like they are expensive.
    I did hear from someone once that sometimes an error on the instrument cluster can make the temp gauge read incorrectly.
    Anyone else heard of that issue?
    Bob
  6. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,639
    9,623
  7. rhys1210
    rhys1210 Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    168
    23
    I'm in Fareham and have vcds.
  8. Andy27168
    Andy27168 Member
    130
    9
    Hi,
    I live in Southampton and work in Portsmouth, I have VCDS, if you still need the codes read drop me a PM.
