Anyone heard of this .....
sprout99 May 14, 2008
  1. sprout99
    sprout99 Member
    373
    microbial slime that can grow in the fuel tanks?
    it causes fuel system blockages and intermittent engine problems.
  2. consilio
    consilio Up the owls!
    666
    Yea right :)
  3. Twizzler
    Twizzler Active Member
    481
    32
    He's not joking. It's a result of diesel needing to contain a minimum 2.5% Biodiesel since March, I think. Widely reported in the media. Garages aren't cleaning their storage tanks apparently leading to the growth of things you really don't want in your fuel lines etc.
  4. Issac Hunt
    1,162
    Its called cladosporium resinae, its more often found in very large kerosene fuel tanks. Such as those in refineries and on aircraft where it can be a big problem.
  5. sprout99
    sprout99 Member
    373
    found on net .............
    Bacteria in fuel tanks occur where fuel and water interface and if left unchecked, grow until the entire contents of the tank are affected.
    In time, the bacteria release a by-product closely related to hydrochloric acid, with the capacity to corrode steel and puncture holes within the fuel tanks, causing leakage and water ingress.
    Subsequently, microbial contamination in fuel - 'the diesel bug' - adversely affects engine performance; a brownish-black sludge clogs-up fuel filters, causing fuel starvation and engine stoppage.
    Droplets of water carried in fuel passing through injectors and nozzles cause excessive wear and "pitting", reducing the injector's ability to provide an even spray pattern.
    The result of this damage is an increase in smoking and fuel consumption.
    it seems our little DSG motor is poorly :puke:
  6. sprout99
    sprout99 Member
    373
  7. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    They do say that you should never let your tank get close to empty as when there is fuel in the tank the "dirt" floats on the top, but when it is empty there is nothing for the dirt to float on and it gets sucked into the engine.
  8. sprout99
    sprout99 Member
    373
    we don't ...my rule is not below 1/4 full
  9. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Whilst in the VW garage today I was looking through their brochures and noticed it said that the 2.0 TDI (can't remember which) can't use biofuel! Have I misunderstood something? Or isn't it called biofuel if it's only a tiny amount of bio?
  10. sprout99
    sprout99 Member
    373
    I have changed filter - car is not lumpy ....for now. Hopefully bio killer will arrive soon.
    Click on image for super close up's
    old and new filters side by side
    the fuel thats coming through from tank
    amber nectar ?? (with free black floating objects)
  11. sprout99
    sprout99 Member
    373
    they mean 100% as it will eat the seals in fuel system
  12. Staz
    6,206
    64
    100% biofuel do you mean? But that's not what it said.
  13. sprout99
    sprout99 Member
    373
    oh sorry....
    but all diesel fuel has a small percentage now i believe
    (100% bio diesel strips the fuel system - it's quite aggressive stuff)
  14. Staz
    6,206
    64
    Ok I'll have another look tomorrow but I got the impression it meant any biofuel within normal fuel.
