ANYONE HAD TO REPLACE ERG VALVE
Stepho Sep 5, 2011
  1. Stepho
    Stepho Member
    444
    As title had loss of power yesterday took it to my local specialist and diagnostics reveal faulty ERG valve, with a cost of £200 odd pounds + labour to repair. Was wondering if the valve can be sourced cheaper. Total cost for repair is near £400.
  2. symun
    symun Member
    147
    do you mean EGR if so then i would just blank off. if not then ignore this reply.
  3. Stepho
    Stepho Member
    444
    Spoke with mechanic and he said its a common fault, nothing to worry about. Used the place on a few occasions and they seem really good. Just really wondering if anyone had this fault and if there were alternatives.
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,888
    721
    Yes had the same fault and the EGR was replaced under warranty.
  5. Stepho
    Stepho Member
    444
    Is this a manifold valve? It may well have been EGR valve, just remembered the letters.
  6. murran
    murran Well-Known Member
    1,545
    39
    if its the type that have a little 2cm flap that turns on a little axle? then yes ive replaced a few at work the flap head falls off leaving the valve completely open. engine coughs spluttlers and struggles to run at all.
  7. rowdyboy
    rowdyboy Member
    804
    19
    £200 labour?!?!? I'd find a new garage!
  8. Stepho
    Stepho Member
    444
    Labour charge is arond the £70 mark and thats at 1hr 30mins. The valve is around the £250 mark plus gasket and seal + VAT, which brings the total cost in at around £380.
  9. B5NUT
    3,888
    721
    On my a4 was the egr valve, car ran fine but had no boost from the turbo
  10. danotto
    danotto VAG HUNTER
    1,090
    mate they are easy to fit albeit im a mechanic but only took me 30mins to change it, where bouts are you? i got a brand new egr valve from a company off ebay for £175. if your near berkshire ill fit it for ya for a small fee.
  11. Stepho
    Stepho Member
    444
    Thanks for the offer danotto but I'm up in Scotland. All done car running fine again.
  12. danotto
    danotto VAG HUNTER
    1,090
    no worries was it the egr valve at fault then. /?
  13. harmless
    harmless Member
    79
    Can a anyone shed some light on how to replace this or check it its faulty im suspecting this my be my problem with random loss of power dont want to spend the stealer prices would much prefer to get my hands dirty any suggestions i have 2.0 TDI
  14. danotto
    danotto VAG HUNTER
    1,090
    its located on the inlet manifold( the right hand side of the rocker cover), and is held on by 4 torx screw bolts the back two are a pain to get on. Removed the 2 electrical plugs,undo the intercooler hose and the two allen key bolts for the breather pipe and it will come out, There is 2 butterfly valves they should both be free but under slight tension. if these are ok there is a black cover on the electrical part of the valve, one of the screws has sealant in it to prevent it from opening, just pick the sealant out with a pick tool or tiny screwdiver etc, once all the screws are out pull the cover off and you with see plastic gears, its common for these gears to grind the teeth off, and therefore making it hard to open the smaller butterfly valve when needed. hope this helps.
  15. jaygeezer871
    jaygeezer871 Member
    166
    I currently dont have a problem with mine.
    Cant the EGR valve be cleaned, if so with what?
  16. danotto
    danotto VAG HUNTER
    1,090
    ive posted above how to remove it, to clean it just use a flat blade screwdriver or something like that as the the valve gets blocked by carbon basically oil and air, this is like a thick resin so screwdrivers work well and maybe some hot water or brake cleaner in a can if you have any.
  17. jaygeezer871
    jaygeezer871 Member
    166
    danotto, your reply came up while i was posting/editing.
    Might well give it go when i have some free time.
    Cheers.
  18. harmless
    harmless Member
    79
    thanks mate ill have a look one wknd when i dont need my car :)
