anyone had this problem before?
MDA Jul 14, 2011
  1. MDA
    MDA sploorer
    87
    hello
    tonight i filled the car up £50 worth :( stuck the key in and it failed to start (key symbol flashing on dash)
    in the end it started after shutting the drivers door and setting the alarm and unsetting it,
    then when i tried it on the drive at home its done it again
    and will not start at all the symbol is still flashing
    ive disconnected the battery and ill have another go before work
    the remote was working too before but ive checked the battery and now it also wont resync to the car..
    ive tried my other key too and thats the same
    any ideas please
    matt
    its a 2002 1.8 T manual
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    The flashing is a immobiliser.
  3. jbcalvin
    jbcalvin Member
    691
    21
    sounds like the reader coil in the ignition barrel might have gone, this happened quite a few times when I worked at an Audi dealer, will need a new barrel if I remember correctly...
    The coil reads the immobiliser code from the key and then disables the immobiliser prior to start up...
  4. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    59
    definitely an immobiliser issue... only time I've had that was when I hadn't used that key for years.... remote worked, but it just flashed the little key symbol when I tried using the key.
  5. MDA
    MDA sploorer
    87
    Thanks for the replies it started perfectly this morning
    I'm wondering if it was an interference issue
    I've left it at home today I'll have a look over it tonight
  6. BahnStormer77
    2,773
    59
    I had an interface issue with an old Mk3 Golf I had a while back: contact points on either side of the key weren't sending the immobiliser signal and would only work a certain way around, but I think the Audi B6's send it differently (wirelessly?)... there's certainly no obvious contact points.
  7. MDA
    MDA sploorer
    87
    im having a autolocksmith out today to recode the transponder
    fingers crossed
  8. MDA
    MDA sploorer
    87
    the locksmith came out
    and had to reprogram both keys as both had lost their code !!
    cost 135 Quid
    anyone have any idea how it happened ? he said its unusual for audis to do it
  9. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    i had the same problem would just randomly stop working but would unlock the car fine
    changed the battery and its never done it since!!
  10. stu_m
    1,440
    ps thats the battery in the fob!
  11. MDA
    MDA sploorer
    87
    cheers stu
    its worth checking for a few quid
  12. MDA
    MDA sploorer
    87
    The problem came back again today called the AA who towed me to a garage
    But while being towed with the ignition on after 20 minutes
    The problem fixed itself again
    I'm tempted to book the car into Audi to get it sorted
    Or send the ecu off to have the immobiliser deleted from the ecu to cure it once and for all
  13. vagtronics
    vagtronics New Member
    I can help if you go for the option of completely removing the immo from the ecu.
    Vagtronics.co.uk
