Anyone had their clutch pedal welded when it's still attached?
jackpilk Feb 28, 2012
  1. jackpilk
    jackpilk Member
    70
    I've had the dreaded clutch pedal snap on me before in my old Golf Mk4 years ago and again last year in my VR6 and it's a right pain to put right.
    Anyway.. Has anyone had their clutch pedal tacked or welded to strengthen it whilst it's still attached to the car? Thinking about getting this done with the current S3 as the last two times it happened I couldn't have been in a worse place if I tried.
    I haven't got the car with me else I'd go out and have a look.
  2. moredoor
    moredoor Member
    160
    You'd be better off removing the pedal and the white plastic clip as one you will melt that clip and two you'll end up burning the carpet.
  3. Customboy
    Customboy Member
    831
    42
    Just buy the kit and keep it spare it's happened to me 5 times!! My last four golfs and my Audi just sods law really worse was last year right before the Blackwall tunnel!!!
  4. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    i removed mine to do it!
    its very worth while doing it even if it hasnt happened
    as you know its a right pain when it goes at a busy junction like what happened to me.
    just be careful of the clutch switch, delicate.
  5. jackpilk
    jackpilk Member
    70
    Thank's for the advice. It'l be coming off soon then to get it done.
    I know it's dead annoying, I thought someone had fired a gun when my last one went!
  6. moredoor
    moredoor Member
    160
    LOL
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    What's all this about?
    I'd like to think there is very little which is new to me when it comes to 8L's. But I've literally never head of a clutch pedal snapping.
    Is this like some common problem or something?
  8. a3tdi2001
    a3tdi2001 Member
    437
    You haven't lived mate.
  9. moredoor
    moredoor Member
    160
    Yep this has been around for years, mk4 golf, 8L A3, Seat Leon, even Seat 6K ibiza and so on.........
    Redirect Notice
  10. 16Klappe
    5,795
    1,186
    You're right, I haven't. Because I've spent all my time pissing about with cars :drag:
    So come on then, what's all this clutch pedal jazz? I have just done some fishing around and found a fair few threads full of people going on about bits of plastic being broken. But haven't got a scooby what this is actually about.
  11. 16Klappe
    5,795
    1,186
    That looks properly rubbish, seems strange.
    I don't know anybody who's had this problem and I've never even heard of it, and I've got 10's of friends with 8L/Mk4's and have been all over them like a rash for years.
    Ho hum, you learn something new every day. Mines fine so I couldn't care less haha.
  12. superkarl
    9,571
    2,464
    you and your mates have been lucky jardo.
    i knew of it happening when i bought my car, then a couple months after bang, straight to the floor.
    theres a section of the peddle which pushes a little rod and its just spot welded so the welds break and bend back. i had mine properly welded all over so no chance of it bending.
    you'l notice creaking noises before it goes
  13. jackpilk
    jackpilk Member
    70
    I know of quite a few people it's happened too. I'm doing mine on the weekend that as well as the pick up pipe.
  14. Paul Robinson
    Paul Robinson New Member
    21
    Mine snapped yesterday, at a roundabout in the middle of town! Heard it crack once and then it snapped next time I tried to change gear....luckily I was less than a mile from my destination so I limped it home. It seems the little plate has snapped off and I'll just get it welded up and I'm back on the road. Seems like every common fault these cars have is happening to me!!
  15. SoljahofSensi
    SoljahofSensi Member
    93
    Hmm, I've noticed mine creaking recently.
  16. Mav190sline
    Mav190sline Active Member
    203
    29
    Mine snapped a few months ago with the Mrs driving back from work leaving her stranded at a roundabout, luckily not to far from home.
    I managed to use a couple of bolts through the holes on the pedal with the "ball" on the end of the little rod between them as a temp repair to get it home.
    Repair is fairly straight forward. When I purchased the bits from Guildford Audi, the guy at the parts desk advised me that the reason the pedal snapped was a weak weld HOWEVER this was designed like this in case of an accident. The pedal should snap (rather than your ankle or shin) to the floor.
    Increasing the strength of this by welding would render this not happening and could cause serious injury to your legs so beware of this when welding your pedal
    Mark
  17. ayfreetee
    ayfreetee Well-Known Member
    1,464
    290
    I welded mine in position on my old GTI, you need to disconnect the battery and put something on the floor so you don't melt your carpet, it's a bit of a squeeze under there, but much easier than removing it.
  18. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    did audi ever revise the part on later models or are all revisions the same ?
  19. s3mad_dude
    s3mad_dude Noggies ruuuule!
    614
    79
    I've started getting a creak from my original clutch pedal. At 180k miles and almost 14 years old now I think I'm going to get a new one fitted. As above, is the part revised or is it still worth welding the new pedal to make it stronger?
  20. SamHendry
    SamHendry Active Member
    646
    135
    43
    Mine snapped at 110k. Local garage welded it for me.
  21. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,234
    2,059
    Kudos :salute:
    s3mad_dude likes this.
  22. Mav190sline
    203
    29
    Parts required for mine were
    Hope this helps
  23. s3mad_dude
    614
    79
    That's awesome, thanks dude
  24. Mav190sline
    203
    29
    Anytime
  25. Mav190sline
    203
    29
    You can follow the how to guide in the stickies
  26. Paul Robinson
    21
    I didn't weld mine in the end it was beyond repair and I realize they are designed like that for a reason so just bought and fitted a new one. I also changed my brake switch as this was starting to play up.
  27. ayfreetee
    1,464
    290
    They are designed to snap in an accident, so you don't snap your ancle instead.
