Anyone had problems with XS/Relentless Manifold?
IrishDave Mar 31, 2012
  1. IrishDave
    IrishDave Active Member
    682
    45
    There are alot of these out there now. What problems have people had so far if any.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I think there is only one fail on the welds reported so far, (prawns) but that maybe an unfair claim as he has used it on the track..
    If this should withstand this is another question....:icon_thumright:
    Welly is not noted to be light footed, and it seemed ok for him the few days he had it on..:)
  3. Jimgrim77
    Jimgrim77 Member
    957
    20
    +1 on that.
    They are awesome.
    Only comment is that they run very hot in a very very confined space.
    When adapting the heat shields at install just ensure that it remains adequate to protect pipe work.
    Can be fiddily to avoid annoying rattle. Took a bit of playing around.
  4. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    I know that Westy has one of these ready to go on his car, and he has had the welds beefed up to try and stop any future cracks appearing, I'm also pretty sure that prawns replacement Mani is going straight to the same place. I think it might be a necessary precaution after seeing the damage to prawns
  5. Prawn
    11,532
    3,470
    Dave: your thread title is missleading, and implies you have a problem.
    it's a bit like me putting:
    *JENSEN BUTTON DEAD*
    ...at some point in the distant future (see what I mean?)
    Anyway, back on topic, To my knowledge mine is the only one to break thats been made to fit and work properly in the first place, but mine is a modified V1 manifold and not the current V2 batch.
    Little difference in the way it's built, so only time will tell. Mine's being beefed up by Dave at Stainless Engineering too like Westys
  6. Jimgrim77
    Jimgrim77 Member
    957
    20
    Agreed. I panicked a little too.
  7. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    What are the release dates for V1 and V2?
  8. Vagworld
    Vagworld Member
    95
    Is it the same as the relentless one? My friends one cracked last week with less then 1000miles on his gt2871r build, he is now going custom manifold
  9. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    I have to say mines coming off next week as ive developed a blow. I took the head off the other week as thought it was the manifold to turbo gasket or dp to turbo so replaced both but it's still there. Engines coming out on Wednesday to sort the clutch and also to find the exhaust blow, I'm hoping it's a gasket but a little bit worried its the manifold as the manifold is the only thing left to check. Chances are though it's just a gasket blowing.
    Only other issue I've had is getting the hidden nut on the turbo stud, what a f****ing pain the ****....
  10. Westy
    Westy Well-Known Member
    17,443
    1,104
    Guys, can you both get photos of your mani's when they come off please so we can see where the cracks (if they have cracked) are.
    Here's a few pics of mine after s3dave reinforced the welds:
  11. s3dave
    10,110
    736
    Yes it is, can you get hold of it? As westy says, it will help people if you can take a pic of the crack to see if it is failing in the same places..:icon_thumright:
  12. beachbuggy
    1,931
    201
    No probs, I know mine hasn't cackled like prawns as I can clearly see there's nothing wrong with it in the same place. I think mine is a gasket issue but will be removing it anyway to ensure no leaks.
  13. Jimgrim77
    Jimgrim77 Member
    957
    20
    Thats interesting.
    I have to say that mine also seemed fine when I had mine apart last/this week.
    The version 2 has lots of extra welds and my exhaust guy was very satisfied with it and felt strengthening work, whilst possible, seemed unnecessary. However, each mani despite being very similar will not be identical.
    Will be running more tests this Tuesday on the dyno once it's off the ramps and pieced back together with new top mounts and that will provide a clearer indication of where it's at.
  14. <tuffty/>
    21,242
    3,879
    Changed title to make it more relevant...
  15. Westy
    17,443
    1,104
    I'm also still waiting on some pics from those of you that have made heat shields to protect the turbo outlet hose.
  16. IrishDave
    682
    45
    Thanks Tufty for the title change, had a couple of beers before posting. So recommendations so far are to get the welds beefed up. Like Westy I would also like to see what people have done heat shield wise.
  17. liquids3
    liquids3 Member
    931
    22
    Mine will be ready in around a week,just received my injectors,nearly there lol
  18. Westy
    17,443
    1,104
    Not good for me mate, I'm fitting mine next Saturday :)
  19. liquids3
    liquids3 Member
    931
    22
    If you do decide to fit a heat sheild,you'll want to mount it after mani is on anyway,so wnt be a problem,so do you have everything ready,injectors fmic dp?
  20. v5 tt
    v5 tt Member
    87
    This wasnt on a TT by any chance ? i saw a TT for sale with a GT28 eliminator with xs/relentless manifold
  21. XFi
    XFi In need of a V8.
    491
    47
    Getting mine fitted on Monday and picking it up on Wednesday, cant wait! Hope I don't get any problems.
  22. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Curious on how these eliminators perform after being mated with a high flow Mani as it is a possibility with a close friends car as contemplating this or a hybrid k04?
  23. Chlippo
    Chlippo Member
    679
    15
    Didnt have any problems on mine so far. My car is stock.
    I beleive those are not designed to run anything other than a K04 or K04 hybrid. A GT turbo would probably need a higher quality manifold.
    As said above, only fitting was the hard part. Im happy with the rest
    Also note that for the price we are paying...im even more than happy with the product
  24. Vagworld
    Vagworld Member
    95
    yes it was, i think he is going to keep it now, he was talking about custom manifolds last night and converting the turbo to t3 flange
  25. badger5
    9,489
    1,999
    i have had several people call me asking about things re manifolds for k04 and of those who ran xs/relentless, all of them were on their 2nd or more after theirs cracked. These were V1's
    V2 weld quality looks no different, and consistency between them is always "inconsistent" anyhows. Pot Luck plays a factor.
    Relentless have been told by Samy re the cracks and say they are going to do something different and send him a sample. They have been told by sammy from me to backpurge the welds.
    We will see.
    who knows..
    Lottery anyone?
  26. Westy
    17,443
    1,104
    I'm hoping my beefed up welds will last a bit longer then.
  27. IrishDave
    682
    45
    So any further pics of cracked manifolds. Where on the mani are they cracking. @Westy. Did you get all the welds gone over. Any pics of heatshields etc.
  28. Westy
    17,443
    1,104
    I'm yet to make a heat shield. The only issues I had at the weekend was the way the mani and the DP fit around each other, or dont in this situation! The DP flange around the top bolt hole wouldn't clear the 4th runner of the mani and I had to grind away some of the material to make it fit flush. Once it was in I then had the problem of not being able to fit a bolt into the hole as the bolt head would foul the 4th runner on the mani too!
    Here was the clearance:
