Anyone fitted their own exhaust?
monty77 Jan 13, 2005
  1. monty77
    monty77 Member
    391
    Do-able on the driveway with a trolley jack? Or should it really be left to a garage with a 4 poster?
    It's the supersprint, so shouldn't have any fitment issues (fingers crossed!)
    Cheers,
    Adam
  2. jediknight
    jediknight Member
    835
    hahahahahahahaha
    if you DO decide to do it on your drive.... you will swear blind that you will never do it there again!!
  3. RichA3Turbo
    5,089
    Its do-able. The biggest pain in the arse will be removing the old one. Fitting the new one will take under an hour. Its much easier with a 4 post lift, but if you want to save yourself the labour charge, give it a go...
    Rich
  4. Ess_Three
    Ess_Three Active Member
    5,383
    14
    I had my ill-fitting Milltek on and off several times...
    As long as you can get the car high enough to get some axle stands underneath, you'll be OK.
    Don't be tempted to work under a trolley jack!
    The hardest thing will be getting the sleeved joint to the cat undone, and off.
    The rest is easy...you simply remove the bolts that hold the exhaust hangers to the 'shell, and drop the complete system, rubbers hangers and metal hanger brackets in a single go.
    With the bolts loose at the cats and the hangers un-bolted you should be able to wiggle the system back and forth enough to get the sleeved joint off the cat outlet.
    Be aware though: if it's the standard system you are removing, it'd bloody heavy!
    You'd be better with 2 people.
  5. Ess_Three
    5,383
    14
    [ QUOTE ]
    jedi-knight83 said:
    hahahahahahahaha
    [/ QUOTE ]
    Oh, I don't know...
    As long as you can get the car high enough, it's no big deal.
    I've had mine on and off numerous times with no complaints...I guess it all depends on how easily the cat joint comes apart.
    It takes longer to jack the car up high, and get the axle stands under it, than it does to whip the exhaust off.
  6. monty77
    monty77 Member
    391
    It's not the labour charge that bothers me, it's :
    a) Some know nothing grease monkey kicking £600 worth of exhaust around with no care
    b) Aforementioned grease monkey fitting it poorly and it leaking like a sod and me having to refit it anyway
    c) I get huge pleasure from doing this kind of thing myself - swapped manifold/turbo on previous car so I'm pretty brave if not particuarly gifted with a spanner /ubbthreads/images/graemlins/smile.gif
    Are the jacking points/axel stand points obvious on an S3? Any special tools/pastes etc.. I'll need before I take the old one off?
    Point taken about weight, new one isn't exactly light either.
    Cheers!
    Adam
  7. Ess_Three
    5,383
    14
    [ QUOTE ]
    [/ QUOTE ]
    Do it yourself then...easy when you get cracking...
    [ QUOTE ]
    [/ QUOTE ]
    Don't use the normal jack points on the sills...
    I use the front subframe mounts, near the rear of the subframe...and something similar at the rear where the rear arms mount to the shell - can't remember exactly where...but it'll be obvious, look for something solid.
    [ QUOTE ]
    [/ QUOTE ]
    Nope...none.
    Metal to metal sleeve joint at the cats...same on the new system...you can use some exhaust paste or high-temp sealer if you wish.
    [ QUOTE ]
    [/ QUOTE ]
    I bet the Supersprint is much heavier than the Milltek...probably not much lighter than standard...and it IS heavy!
  8. RichA3Turbo
    5,089
    [ QUOTE ]
    Cheers!
    Adam
    [/ QUOTE ]
    Its the reason i would do it too... You can be pleased with yourself when its done and you know you did it. Its the reason i did my turbo upgrade myself (well... partly!)
    As glen says, the sleeve joints can be a massive b*tch to get loose! They are usually seized up a bit and a real pain the shift. On a m8's A3 we have to use a whole lot of penetrating oil to loosen it up a bit and use a mallet to tap it off. Took about 45 minutes for the one joint!
    Have fun!
    Rich
