Anyone fitted the tailpipes from the accessory range?
dickys3 Apr 12, 2006
  1. dickys3
    2,954
    Looking in the accessory catalogue there are tailpipes that I wouldn't mind fitting onto my droopy tdi pipes!
    Anyone done this? They seem quite cheap.. Any pics?
  2. marriedblonde
    marriedblonde Active Member
    4,371
    I'm sure someone on here has but Eeef had a set of tip's welded onto his by, I think, powerflow.
    Possibley a cheaper option but if you have a part number I can see what sort of price I can get for you?
    J.
  3. dickys3
    2,954
    [ QUOTE ]
    J.
    [/ QUOTE ]
    Do you work for vag then mate?
    Thanks for the offer on getting me a price, however I can get VAG Parts at cost prices.
    Rich.
  4. wilko
    wilko Top Gear
    725
    Do you have to remove the current covers before fitting any new ones then?
    How much do powerflow cost to do this? I was thinking about doing this but I might just wait and get a full miltek instead.
  5. [ QUOTE ]
    [/ QUOTE ]
    As far as I am aware you can only fit the tail pipes in the accessory catalogue if you have the Vortex rear bumper fitted. I believe this is because with the Vortex fitted the standard pipes are too short, and become recessed. You can get a company like/or Powerflow to give you straight pipes. Though the back of the car does get dirty very very quickly, but it looks a lot better /ubbthreads/images/graemlins/cool.gif
  6. Eeef
    Eeef Lord of War
    1,607
    How right you are. It would appear that fitting them also makes your car look fekin dirty as well....
  7. Know the feeling. The Milltek has the same effect. Just glad that the Silver hides the dirt quite well. Though it is annoying when you spend 1-2 hours cleaning the car to drive it down the road and it is dirty again!
  8. dickys3
    2,954
    Well I've now got the pipes, and I think they will look really good.
    Gotta break the weld where the pipes droop downwards and fix the new pipes on with grub screws.
    Got to find some time to do it now though!
  9. jonnye
    jonnye New Member
    29
    had powerflow ones on my A3, looked and sounded great
  10. Paulsporta3
    Paulsporta3 New Member
    10
    I bought them a few weeks ago on Ebay and had a little fun breaking the old welded droopers off but managed in the end. The original pipes under neath the old covers also have a slight downward angle which I left as you don't see it after the polished pipes are fitted.
    One question which might seem daft but got me wondering, will the lip on the exhaust pipe cause any performance issue ie. backpressure build up as the opening is slightly reduced because of the lip?
  11. d3fy
    d3fy Active Member
    1,412
    So we can come to you for prices then Rich? ;)
  12. Boydie
    Boydie Guest
    its only an aesthetic modifications - wont cause any performance problems or gains!
    i have the vortex rear valence to go on aswell with the exhaust tips but havent had the time yet
    whats the difference between the sportback rear valence and the normal one? i might be slightly worried i have a sportback jobby!! :faint:
  13. h5djr
    9,383
    1,727
    I have a Sportback with a 2.0TDI-170 engine. Because the 170 engine has a DPF it can have straight exhausts rather than the slightly turned down versions on the 140. As standard mine has chrome tailpipes. The rear bumper/valance is certainly different on my Sportback to the one fitted to my previous 3-door.
  14. Badley
    Badley Member
    82
    I'm going to end up with an S-line, I presume these tail pipes will fit as the 140 shares the same bumber as the 170.
    BTW I thought the VAG's styling parts were from Votex and the US forum is called Vortex?
  15. dickys3
    2,954
    I would love to supply them cheap but unfortunately I get them off my bro-in-law who works for Audi. And He can't supply loads.
    I fitted mine a year ago and they still look fine..
  16. i had two new style rs4 oval 5" tail tips/pipes put on recently. no change in anything.....BUT LOOKS GREAT!!! with18rs4 alloys the back end looks loads like rs4 .. will post pics if i can work out how top do it.... i'm newbie!!!
