Anyone fitted the Cupra front lip to an S-Line....
Jason B Jan 13, 2009
  1. Jason B
    Jason B New Member
    25
    ....and if so, how does it look and do you have pics?
    Been looking at them on Ebay and quite fancy the idea of fitting one as it looks OK in the pics but I am just not sure and would prefer to hear and see from someone who has actually fitted one to a B7 S-Line.
    Just want to know what's involved in the fitting and how much the spoiler has to be hacked and if it looks good when fitted.
    Thanks in advance.
  2. Damian_25
    Damian_25 New Member
  3. quattrojames
    14,060
    583
  4. Jason B
    Jason B New Member
    25
    That really dosn't look bad at all. Will drop them both a PM to ask about the fitting. Thanks very much for the links guys....much appreciated.
  5. M7R
    M7R Type Approval Engineer,
    216
    if you do get one go to VW/Seat parts dept and order one, they are only £20 over the counter.
    I looked at it went and got one but then descided against it as it didnt look quite right on my grey car, and also it didnt quite follow the bumper unlike on my old mk4 golf, it would need a little heat to tease the sides out so they arent as bent if you see what I mean.
  6. StagsyA4
    StagsyA4 Member
    96
    Please pass on any details of fitting as I am currently looking at doing this mod too! cheers mate! :thumbsup:
  7. Yellowtrophy
    Yellowtrophy Member
    108
    Like he said - I'm looking to do this too - for £20 over the counter you can't go too far wrong!
  8. Richardesty
    Richardesty loves quattro
    742
    20
    Simply a case of:
    1 - order from your local seat dealer
    2 - collect from your local seat dealer - hand over about £23
    3 - raise the front of the car to ease access
    4 - trim a few 'location lugs' from the spoiler
    5 - line it up with a friend, and fix with either bolts or self tappers
    6 - trim the ends if needs be
    :beerchug:
  9. Jason B
    Jason B New Member
    25
    Fantastic:icon_thumright:
    Bit if a cheap but very effective mod then. Think this will have to be done as it is a great looking addition for something that is so simple.
    Ta much for the info.
  10. razza1
    razza1 Well-Known Member
    3,075
    829
    anyone got the part no.? And can you order them from an Audi garage, as my nearest Seat garage is miles away?
  11. Richardesty
    742
    20
  12. ultramodz
    ultramodz 06 A4 2.0T FSi S-Line SE
    515
    Yeah, this basically... though I did it on my own & didn't raise the front of my car - I should have as it's only about 6 inches off the ground. :)
    I bought 2 packs of black self-tapping screws - one pack of about 2-3cm long screws & another pack of longer ones (5-6cm).
    I then used my Dremel to modify the tabs on the splitter, smoothing them flat & also trimmed down the central struts. I wanted the splitter to curve up a bit in the middle to follow the line of the bumper, but you're best off trimming a little bit off at a time & then trial-fitting until you decide on how you want it to sit.
    I pre-drilled a hole in each tab (about 20 I think), then positioned the splitter on the car using wide masking tape, making sure it was evenly positioned on each side (where the wheel arch begins, etc)... then it was just a case of screwing through my guide holes into the bottom edge of the bumper using the smaller screws.
    In the pic, you'll see how the central section is hanging down a bit - I hadn't added the longer screws which I have on there now. The splitter struts are kind of V-shaped, so as I screwed it in, it pulled tight.
    My coilovers have settled in now & so the car's a fraction lower. That, combined with the crappy UK roads/camber/ramps/etc has meant I've scraped the splitter a few times. It seems the screws work well as they just pull out when you catch it & you can just put new screws in.
    I like how it finishes off the bumper & looks OEM, but still adds an agressive edge to the car's appearance.
  13. Richardesty
    742
    20
    That looks awesome on a black ride :hubbahubba:
  14. razza1
    3,075
    829
    Just fitted:
  15. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    heres mine on my sportback i rubbed it down glossed blacked it and 5 clear coats looks good with the optics grill
  16. razza1
    3,075
    829
    Looking good...did think about painting it as well to make it blend a bit better...
  17. ultramodz
    515
    I went over some road debris the other week, which ripped straight through my splitter & tore a big hole in the inner sidewall of my tyre... anyway apart from losing my splitter & having to spend out on a new tyre, everything was ok.
    Now I need to order a new Cupra splitter - good job they're only cheap!
  18. jwhat
    jwhat Member VCDS Map User
    541
    That didn't sound like fun!
    I think I would have had to change my pants too :blink:
  19. ultramodz
    515
    It wasn't too bad actually - the 35 profile tyre combined with my car's coilovers being set low & pretty stiff meant the rim didn't drop down & the car stayed pretty flat... it just felt like somebody had replaced my steering with jelly!
    I wouldn't like that to happen in a 4x4 or anything higher off the ground - the wheel could quite easily act as a pivot point if the higher sidewall tyre blew out & the softer suspension reacted at 80mph.
  20. jwhat
    541
    I fitted my Cupra splitter on Sunday and it :rock:
  21. TorqueTerrorist
    TorqueTerrorist www.sprayplan.co.uk
    485
    94
    If you have headlight washers be careful as...erm...I've heard that using self tapping screws can go through the water hose that runs right where you fit the splitter. I of course did not do this....well maybe a little lol
  22. TorqueTerrorist
    485
    94
