Anyone fitted an XCarlink USB CD changer?
Bigman Aug 20, 2010
  1. Bigman
    Bigman Cornish and Proud!
    85
    Hey Guys
    Just wondering if anyone has fitted one of the USB CD changers from XCarlink, I have a Concert 2, i can see how it all plugs in etc, but the car currently doesn't have a CD changer, does anyone know whether anything will need programming within VAGCOM to tell the car it now has a CD changer?
    Adam
  2. AndyMac
    9,832
    45
    No just plugs in and it picks it up automatically
  3. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Iwheelonly fitted the same unit in my car last weekend , its worth fitting it in the glovebox,remove the glovebox punch out the pre formed hole feed the wire to the head unit. I have just got some velcro pads and stuck it the roof of the glovebox so it looks tidy, i can post a picture if you like .
    Sound quality is alot better than cd especailly using the sd card.
    HTH
  4. Bigman
    85
    Ah, thats good, thanks.
    Thats pretty much what I was planning on doing, pulled the radio out today to have a quick look, gunna have a bash at fitting it tomorow. Pic would be good, just so I can see where other people have fitted the box.
    Adam
  5. RMH1A4cab
    551
    19
    Ok , here you go .
  6. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    ????? auto pick up, with no coding ???? hows does that work andy ??? rmh1a4cab's required coding .
  7. Bigman
    85
    Hmm, well I should atleast be able to get it all wired in etc, although I am not 100% sure, but I think that I may need an adapter after having another look, as the plug that goes into the radio from the Xcarlink seams to fit where part of another plug is, although there are no wires going into this part of the plug, is it possible to just carefull mod the plug so that the Xcarlink one can fit in there too??
    Lea, If it needs coding, any chance you would be able to do that for me? Speedy is away next week and I was hoping to get it done before I go to germany.....
    Adam
  8. 1wheelonly
    2,385
    111
    no problem big fella, come round anyway mate, we'll sort it, i have a few looms floatin about, if not, we will adapt yours no problem mate, pop round, wont take long.
  9. RMH1A4cab
    551
    19
    Sorry to be a pain lea and for hijacking this thread, but did you have any joy in finding out the info with regards to my radio/dis information not being displayed.
  10. Bigman
    85
    Hey Guys, I made a visit to Lea (1wheelonly) today, and we managed to get the Xcarlink all wired in, which was abit interesting as whoever wired the parrot into my car was a right butcher, its a proper mess back there! Any hoo, got back, made up a USB stick with folders named cd01 - cd06, stuck some songs in each and it works a treat, realy happy with it! I tried the stick with a cd07 folder, but it appears that it will only recognise up to 6 folders, but that isn't a problem realy with up to 99songs in a folder!
    Adam
  11. RMH1A4cab
    551
    19
    Lea does know his stuff.
    The Xcarlink is a great bit of kit for the money , i've filled 2 8GB cards ready for my trip next week.
    Enjoy .
  12. 1wheelonly
    2,385
    111
    yes got the codes mate from adams motor whilst i was plugged in,so when ever your about mate or when we do your roof module, ill activate it for ya mate no problem, still cant work out why yours doesnt show the code addaptions though.
  13. 1wheelonly
    2,385
    111
    adam, dont forget you also still have the option to connect your iphone to it, i guess you could get alot more than 600 songs on that !! lol
    have you tried the usb and a SD card at the same time ????
    was just woundering if they worked together? which would give you even more maybe
  14. Bigman
    85
    Yeh, I do have abit of music on the IPhone atm! I have not tried an SD card and USB stick, I may have to try it with the one out of my camera, I will let you know how it goes!
    Adam
  15. RMH1A4cab
    551
    19
    Cheers lea i'll give you a bell when it arrives , i'm away next week so hopefully it will of turned up by the time i get back .
    As for the Xcarlink the sd card overides everything you have to clip the card out for the 3.5mm jack/usb to work .
    I've sorted the interference out on the car link i was using a **** 3.5mm extention lead, changed it and all is ok, still got the noise on the bluetooth even when the enigine if off , get worse with the engine running , checked the wires and all seems ok, any ideas .
