Running the cable from the dash to boot involves removing a fair bit of interior trim. "Dave N" posted a guide to doing it on the old forums, which I had the presence of mind to take a copy of at the time...
[ QUOTE ]
DaveN
Rookie
Member # 118
Rate Member
posted 22 August 2001 12:14
I did a similar install about 2 months ago.
As said previously run the cabling behind the glove box to the left side.
The glove box is removable be removing about 6 torx screws behind the plastic snap on cover on the side of the dash, you can see it if you open the door. There are 3 screws if you open the glove box and one beneath the glove box.
The trim on the floor is just clipped down and can be prised up.
To get the side panel off is a bit of work, first remove the rear seat, this is done by folding the seat completely forward, for the left side get a screwdriver and push down the hoop the locks the seat in on the left side.( its hard to explain but looking at it you should see what I'm talking about).
Now with the seat removed begin to pull the side panel out from the bottom beginning at the front, there are 4 clips at the door side, two at the bottom and about 3 across the top. With a bit of gentle levering these all open allowing access to the area through to the boot.
Be careful with the clips on the side panel as they can break off but can be refixed using Super Glue or Epoxy.
Before anyone say's I could of done it easier, I was also putting in a S25 phone car kit and I hid the control box behind the glove box.
Best of luck and take your time.
Dave N
[/ QUOTE ]
Someone else (Drillslinger?) advised that there is a special trim-puller tool available for prising the clips that hold the trim in place away from their sockets without damaging them (easily done).
I didn't have one to hand, but it would probably be worth seeking one out as I had to apply a worringly large amount of force to pull the trim out! /ubbthreads/images/graemlins/shocked.gif
Mark.
