Anyone fitted a DIY tyre pressure monitor?
psychopomp1 Jun 15, 2013
  1. psychopomp1
    psychopomp1 Member
    164
    14
    Since i have a poverty spec SE B7, thinking of getting this DIY TPM as it only takes a few minutes to install. Just wondering has anyone fitted such a TPM and are you happy with it? Its on sale at the moment at £70.
    Cheers :)
  2. psychopomp1
    psychopomp1 Member
    164
    14
    Ok took the plunge and bought it. Overall very happy with it, an absolute doddle to install and the display unit plugs in neatly into the cigarette lighter socket. Whilst driving the display scrolls showing the tyre pressure in psi. The only downside is that the wheel cap sensors (black) are a bit bulky but i don't find them too obtrusive. Will post some pics later on :)
  3. hades-
    9,481
    646
    yeah id like to see how they look
    iv retrofitted oem tpms in the past
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,278
    2,793
    So, how does this work? Do the monitor caps send information to the display wirelessly?
  5. psychopomp1
    psychopomp1 Member
    164
    14
    Yep, the sensors (built into caps) transmit wirelessly to the display...i believe the frequency used is something like 433 mhz. The sensors take a replaceable battery (CR2032?) which is supposed to last 3-4 years. Just hope the local chavs don't pull off the sensors because even though they're fitted with locking nuts, i'm sure with a bit of force they can be pulled off :(
  6. jdp1962
    8,278
    2,793
  7. marky67
    marky67 Member
    56
    10
    Do you need to get your wheels re-balanced.... 'cause they look a bit bulky?
  8. psychopomp1
    psychopomp1 Member
    164
    14
    Some pics :)
  9. Def-87
    Def-87 B7 2.0 TFSI Quattro
    46
    Im very interested in these. Could you send me the website where you brought them??
  10. jdp1962
    8,278
    2,793
    Click on the word "this" in the opening post.
  11. psychopomp1
    psychopomp1 Member
    164
    14
  12. jdp1962
    8,278
    2,793
    psychopomp1 likes this.
  13. jdp1962
    8,278
    2,793
    Arrived today, and were fitted and up and running inside ten minutes. Unfortunately, I only checked the display after I'd tightened all the lock nuts, and that's when I noticed the front right is reading 36psi when all the others are reading 37 (I wouldn't mind but I checked all of them with my compressor before fitting the TPMS sensors).
    It's now raining, so I can't be bothered to un-loosen the sensor and add some air to the tyre. It can keep.
  14. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    I'm quite tempted with the oem style ones that fit the rim. Has anyone tried them?
  15. jdp1962
    8,278
    2,793
    Tweaked the pressures again, and I now have a reading of 37psi all round on the Steelmate monitor display - which, incidentally, corresponds to 38psi on the display of my compressor. The discrepancy doesn't really matter, so long as I know it's there. The point is that the tyres are at the pressures I like them at.
