Anyone fancys a job for a drink wink wink
L3WJX Oct 11, 2012
  1. L3WJX
    L3WJX Member
    223
    Hello,I am in the Essex area and I'm not to mechanical minded so I would like to give someone drink tokens to clean my egr valve and my turbo as I think my vains are sticking,iv seen a mr muscle thread that looks like it works and would like this done,sound like the problem I have with my car at 2000rpm with the mr muscles trick has fixed problems like mine'i If anyone is interested pm me cash waiting.....
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    I think if you search you will find a enough pictures to guide you through both jobs. Im not sure anyone would be willing to use mr muscle on another car, i certainly wouldnt risk it!
  3. .Jas.
    .Jas. Member
    134
    What model have you got? If it's a 2.0 it's fairly easy. If it's a 3.0 then it's a bit more difficult!
  4. L3WJX
    L3WJX Member
    223
    2.0 mate not to good with stuff like this lol
  5. CHEZ
    CHEZ moderately amusing Supporter
    4,189
    867
    thats a defeatist attitude! use the guides on here and have a few beers at the same time!
    save a few quid and gain knowledge mate!
  6. NHN
    29,577
    1,779
    Its not a 5 minute job & tbh the Mr Muscle way is only a temp solution if it actually works aswell, best bet is to remove turbo & clean it properly.
  7. L3WJX
    L3WJX Member
    223
    Cheers for the replys guys,just spoke to my friends boss who is going to clean the turbo take it off and clean the egr valve for £200' does this sound about right,
  8. L3WJX
    L3WJX Member
    223
    Egr valve has now been blanked still the same poor mpg white smoke out the back And still shakes at idle,I'm now thinking injector or loom what's best to do ?
  9. SL11CKK
    SL11CKK Active Member
    709
    Honestly I dont think its worth £200. Firstly with that money i can get an indy to change clutch and flywheel. If u are going to go ahead I hope you get him to clean intake manifold by bolting it off.
  10. SL11CKK
    709
    Also try BG244 in your tank to see if it makes a difference
  11. L3WJX
    L3WJX Member
    223
    Bg244 is in my tank already but still nothing,this is really ******* me off now,engine really shakes sometimes at idle sounds a bit like its running on 3 but no fault codes,mAybe could be running on 3 I have vagcom and checked injectors them self there all between -2.5 and + 2.5 if this is right ...
  12. .Jas.
    .Jas. Member
    134
    How long has the BG244 been in the tank? You need to give it at least a third of a tank to clean up your system. It won't make any difference straight off.
  13. L3WJX
    L3WJX Member
    223
    Woke up this morning to no water in the coolant just went over night had to refill this morning,but I had a head gasket test done but nothing seemed wrong
  14. mm707
    mm707 Member
    284
    Have a look under your oil filler cap or on the dipstick for white / yelowish sludge - this would most likely indicate that water is getting into the oil
  15. NHN
    29,577
    1,779
    Also try putting in a dry place & put cardboard/paper underneath to see whereabouts its coming out from, a general area will help trace it, but thats a vast loss of coolant tbh if it was empty.
