Anyone ever removed the steering wheel?
PaulJC84 Dec 7, 2005
  1. PaulJC84
    PaulJC84 Owner
    2,920
    17
    Just wondered if anyone has and removed the airbag etc?
    Cheers.
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    I have and it's relatively easy, just uplugged the airbag at arms length, nothing untoward happened. You will need a big socket though (24mm?, can't remember exactly), I had to go and buy one.
  3. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    Not sure about the A4, but the A3 is a massive torx nut...Had to use my 2" breaker bar to release it...was f'in tight!
    Rich
  4. Anito
    Anito Member
    434
    How might depend on the steering wheel. I have a 3spoke and it's a simple remove of a coupe of torx screws around the back and your in business.
    Something in the back of mind mind tells me you should do something with the key (like making sure it's removed)
  5. joost
    joost Active Member
    1,169
    Disconnect your battery first (obvious but essential!!) Then there are allen key screws on the rear of the wheel (not sure if there the same number on each style of wheel but there are 4 on my 95 1.8). Undo these and the airbag will fall forward. Then just undo the wiring, BIG nut and Bob's your uncle! /ubbthreads/images/graemlins/smirk.gif
    When you put the airbag back on and are ready to reconnect the battery, switch the ignition on, put your lights on (and maybe a couple of other things that will take some power out of the battery), leave the doors open and then reconnect the battery. If you don't, you could have a rather loud bang as the airbag goes off (voltage spike) /ubbthreads/images/graemlins/frown.gif
    Done this a couple of times and mine's not gone off (yet /ubbthreads/images/graemlins/wink.gif)
    HTH
  6. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,471
    3,034
    Do you have to disconnect the battery? Can you not just remove the airbag fuse?
  7. AndyMac
    9,832
    46
    I didn't even remove the fuse, they're not armed with the ignition off
    If someone runs into your car when it's parked up the airbags don't go off
  8. joost
    joost Active Member
    1,169
    Strangely enough, that's what I thought but was only following advice from an (allegedly) qualified source.
    Since I'm not that mechanically minded or qualified, thought I'd better follow their advice as didn't fancy having to fork out for another airbag.
    Apologies if I've caused any confusion Soupie /ubbthreads/images/graemlins/confused.gif
  9. moschino
    moschino Member
    252
    As long as the ignition is off the Airbag should not deploy.
    Make sure you earth yourself first by touching the chasis to prevent static electricity from setting it off accidently.
    As long as you re-connect the Airbag before switching on the ignition you should not need to have the warning light reset.
