Anyone around Cambs that can do a VCDS DGS Adaption for me?
jaydav2306 Aug 7, 2013
  1. jaydav2306
    jaydav2306 Member
    217
    As the title says anyone thats real nifty with VCDS that can do this for me?
  2. NHN
    29,295
    1,701
    What adaption are you referring to?
  3. jaydav2306
    jaydav2306 Member
    217
    I've heard that it can be "reset" recently had a DSG oil and filter change and sometimes it's still a little jerky and I know that Audi will want silly money to do it
  4. NHN
    29,295
    1,701
    That should of been done when the dsg oil/filter was done.
  5. BenC00
    BenC00 Member
    99
    Actually mine feels jerky since having its DSG oil and filter changed - i have VCDS, can someone tell me how to check if it was reset? ... and how to reset it if required? :)
  6. BenC00
    BenC00 Member
    99
  7. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    125
    just follow this procedure.[h=2]Basic Setting[/h]Prerequisites:
    • Fluid Temperature 30...100 °C (86...210 °F), see Measuring Blocks, Group 019.
    • Selector Lever in P
    • Ignition ON
    • Engine ON (Idling) for one minute or more
    • Brake Pedal operated (hold for the whole procedure)
    • Throttle Pedal not operated
    NOTE: Be sure to perform the following steps in the sequence shown, followed by the defined test drive.[Select]
    [02 - Transmission]
    [Basic Settings - 04]
    BenC00 likes this.
  8. BenC00
    BenC00 Member
    99
    Thanks... i'll give it a go and report back.
  9. NHN
    29,295
    1,701
    Hold up, remember the details on the wiki were for a dsg car, yours are stronic's, so check with ross-tech if the procedure is the same before acting upon, just to be safe.
  10. BenC00
    BenC00 Member
    99
  11. NHN
    29,295
    1,701
    Isn't your stronic 7 gear?
    If so then check with RT, I would still check with RT & also if your box is 09G, if not then again, check with RT.
  12. BenC00
    BenC00 Member
    99
    Thanks for your advice :) ... i just checked an old VCDS scan and my 6 Speed S-Tronic is type 'DSG/02E'
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 051 T HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1963
    :racer:
  13. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    A VCDS scan will tell you what box is fitted..i.e. This is of my car and shows it's a 02E box which follows RT file
    6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki
    Part No SW: 02E 300 011 DC HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1905
    Revision: 04844002 Serial number: 00000811271320
    Coding: 0000020
    Shop #: WSC 06314 000 00000
    VCID: 53AEE47FF2EE69B
    No fault code found.
