Anyone able to recommend free software for ripping DVD to iPad
Good 2 B A Gooner Nov 29, 2010
  1. Help please techy guys! :sly:
  2. mitch78
    mitch78 Active Member
    2,350
    Handbrake
  3. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
    :busted_cop::busted_cop::busted_cop::busted_cop: !!!
  4. Ads
    Ads License to drive
    8,230
    610
    Videora.
    Handbrake is a good call though.
  5. beanoir
    beanoir Large Member
    2,171
    31
    I use Handbrake and it works ok. I've not tried anything else though, so not an expert opinion!
  6. Ads
    8,230
    610
    Videora is better for the novice user as its got a simple wizard type interface, and it even places the converted video into itunes automatically for you.
    Downside is that you have to be connected to the internet to use it.
    Conversion speed and results are pretty much the same for videora and handbrake.... 20-30mins to convert a 700mb video file on an average spec'd computer.
    For straight forward converting then videora.
    For more advanced tweaking of the video file then go for handbrake.
    Oh, and handbrake you can queue videos for conversion. So you can set say 5 videos to convert one after each other without having to kick off each one manually.
  7. mitch78
    2,350
    Have you seen the latest version of handbrake? It has presets specifically for iPad, AppleTV, iPhone, etc. Perfect for a novice. Far better than previous versions in that respect.
  8. Ads
    8,230
    610
    Yeah, handbrake is what I use and those presets are useful. I think the fact that even after you select say iPad it still displays the default values and it can all look a bit complicated. Also the command prompt box popping up during conversion might give a computer novice a shock.
    Videora's interface is one of the easiest I've seen. It asks you which file you want convert, then asks what you want to name it, then asks if you want the audio/video quality 'good' or 'high' or 'best' instead of just giving you numbers to play with like handbrake does, then it gives a button to click to start converting. There's a little progress bar with time left till completion too.
    Once it's finished it opens iTunes for you and sticks the converted file in there, ready for syncing.
    Downside is that it isn't a multi device program like handbrake. Videora only offer separate software for iPhone conversions or iPad conversion, etc.
