Anybody with VCDS and a 2.0 TDI BKD Engine, willing to get a value for me?
Wabby Oct 16, 2011
  1. Wabby
    Wabby Member VCDS Map User
    43
    If anybody has access to VCDS and have a 2.0 TDI BKD engine, please could you see what your values are in the following screen:
    Channel 5 of Adaptation on Engine.
    This channel holds the details for cold starts, and I think myn has been messed with - hence wanting a stock value if anybody has them?
  2. zippyijk
    zippyijk Member
    70
    I'll get it for you this evening if no one has posted in the mean time.
    The wife has taken the car for the day.
    I read your other thread, you were able to search elsawin to find that problem? How did you do that?
    I've got elsawin but don't use it that much as I've to run it in windows virtual pc (xp mode).
  3. Wabby
    43
    I just browsed:
    Technical Product Info > Engine > Function > Engine problems involving starting behaviour > Cold engine difficult to start, misfires and has white smoke.
    Low and behold, my exact symptoms, and my engine code and year is the exact requirement for resolution by ECU software upgrade.
    IF I can make relevant changes using VCDS I will, otherwise its a trip to the dealers with my pants down!
    BUT: Anything is better than my first assumption of porous/cracked cylinder head :D
    zippyijk likes this.
  4. zippyijk
    zippyijk Member
    70
    Yeah definitely!
    I had the porous head problem, got it fixed but cost a fortune :(
    It not the cost that annoyed me its the fact I could have gotten a load of mods done with that money :)
    Cool, I'll try that out next time. Didn't realise you could search like that in elsawin.
  5. zippyijk
    zippyijk Member
    70
    Right went to check it there but getting a security access error for that channel. Do you know what the security pin should be or how to get it?
  6. Wabby
    43
    Its OK now mate. I have discovered that I cannot change that value on this ECU anyhow - It seems to vary based upon the previous starting conditions.
    Trip to Audi for the software update me thinks.
    Cheers anyhow mate :)
