Anybody try retrofitting a RS4 FBSW?
Rabbit222 Jul 25, 2008
  1. Rabbit222
    Rabbit222 Active Member
    708
    125
    43
    As the topic states, has anybody tried this? Will it be a simple but expensive mod? Yeah I know, Its friday :)
    :redface:
  2. S3IZZO
    S3IZZO Guest
    I prefer the S3 FBSW to the RS4 one personally.
  3. Rabbit222
    708
    125
    43
    Yeah, I'm just curious to see if anybody has taken the plunge and tried this.
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    i liked the brushed alum bottom part but not so keen on the suede. As for fitting, sorry, no idea if its physically possible.
  5. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    The only thing about the RS4 wheel is that if you already have the MFSW you'll be missing some functions on the RS4 one. From what I remember the RS4 wheel only has 4 buttons for volume up\down and track up\down. No mode button, no SDS button and no scroll wheels.
    In theory it should fit as long as it is a 12mm internal wrench bolt jobbie holding it in. The only difficulty you might have is with the airbag loom and MF controls.
  6. Rabbit222
    708
    125
    43
    Thanks for that Marc....quick question. My S3 FBSW has a MODE button but is not functional. What functions does the MODE button control?
  7. sleeves_008
    sleeves_008 Member
    The only thing I use mode for is when I press it, I can access my phone book on the DIS and scroll down to the name I want to dial. Think mode is only used in the phone prep kit, but I will stand corrected.
  8. MarcQuinlivan
    2,539
    9
    The MODE button only works if you have BT. It is used to switch from Radio\CD to phone on the display so you can view your phone book.
  9. JamS3
    JamS3 Active Member
    2,258
    24
    Think someone on here has done it a while ago.....
  10. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    It's worse than that ... yes the RS4 FBSW has only 4 buttons, but the SCSM detects that it's an RS4 wheel and will not accept the coding to make them work as volume and track up/down buttons (on an RS4 the buttons are the three trip computer buttons and the Sport button). So you get a FBSW with no working buttons - not much use really.
  11. N8
    17,163
    720
    Just get a FBMFSW
  12. sakkie69
    sakkie69 2008 Audi S3
    199
    They are standard item in South Africa.
