Anybody had succes on the ABS wiring system?
dieselfitter251 Nov 18, 2008
  1. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    Continuity, wiring etc?
    I really don't want to get rid of Stinky but if I cant sort the ABS out myself I may have to take it to a layby on a moor some where, shoot it in the manifold :gun2: and set on fire!!!!!!
  2. aragorn
    17,956
    701
    You just need to be systematic.
    Swap the sensors left to right and see if the fault moves, if it does then its the sensor, if it doesn't its either the wiring or the trigger ring...
    As for the wiring, it will just be a case of getting the multimeter out and testing continuity between the ECU and the wheel end of the wiring. Find which pins match up with the wheel using the wiring diagram and get testing.
    You keep creating new threads, so its kinda hard to track your progress with this, what have you done or tried so far?
  3. dieselfitter251
    1,120
    Sorry about the threads.... I'm really no further forward than I was yesterday as I've got a shed load of work on, it'll be tomorrow or Saturday before I can have a real go at it.
    Promise to keep just one thread going.....:slapped:! Cheers!
