any1 any gd with vagcom
skinz Oct 16, 2012
  1. skinz
    skinz Member
    233
    im trying to set up vagcom on my laptop and its asking to set up the interface to 1 of the com ports(usb ports) its giving me the option to pick com1 com2 com3 com4, but my usb's start from com5 com6 an com7 so it cant find the interface, can any1 help plz cheers
  2. hades-
    9,481
    646
    is it genuine or snide ?
  3. skinz
    skinz Member
    233
    ebay special
  4. hades-
    9,481
    646
    thats the problem then
    dont they offer support by phone ?
  5. skinz
    skinz Member
    233
    i cant remember the bloke i got it off, its not on my ebay anymore
  6. HibiscusS4
    HibiscusS4 Member
    97
    This is a PC problem and not a VAGCOM problem. You will find that you can change the port number of any USB to Serial device. Dont worry that your PC thinks com1 to com4 are already in use, they are not so just find out how to change the port number an dchange it, VAGCOM will then work.
    I had to do this with my ebay lead. Go to device manager, find the port under the ports heading and right click on it, snoop around until you find the change port option or an advanced setting option, it will be in there I am sure.
  7. aragorn
    18,542
    865
    yeh, just move the com port down as mentioned above!
