any spec info on 96 a4
graham A4 Jan 24, 2009
  1. graham A4
    graham A4 A4
    17
    does any know roughly what the bhp and 0-60 time would be on a 98 a4 1.6e
  2. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Judging by my old A4 1.6 I would say about 100bhp and 0-60 in about 15 seconds. I found I was ragging the living daylights out of it all the time.
  3. griswold
    griswold Member
    353
    Just had a look on parkers if I got right model
    0-60 11.5 101bhp propbably less if tired and not looked after
  4. Broken Byzan
    13,237
    466
    yeah the 1.8 SE wasnt much quicker it was 10.5 iirc
    I hope mine is around half that now,lol
  5. aragorn
    18,608
    871
    you'll probably find the 1.8T will do better fuel economy than the 1.6 as your not having to kick its **** all day long to get it moving...
    Imo a 1.6 A4 would be horrible to drive. Likely similar to driving a 1.0 12v corsa...
  6. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    according to 98 brochure
    101 bhp at 5300rpm
    140nm at 3800rpm
    119 top speed
    and 0-60 11.9 sec.
  7. Broken Byzan
    13,237
    466
    My 1.8t is better on fuel than the 1.8NA ever was. And a bit faster too,lol
  8. Siena
    Siena Active Member
    2,626
    Yes, the 1,6 is slow.
    But nicer to drive than the 1,8 20V n/a - it's a nasty car to drive.
    Yes, it has 25PS more than the 1,6, but it just felt lifeless at low speeds, was harder to keep it on the boil when moving in fairly dense traffic.
    The 1,6 on the other hand, felt a lot more linear in character.
  9. olds_kool
    1,094
    15
    and quicker than i thought it would be
  10. aragorn
    18,608
    871
    is the 1.6 an 8v?
    If so you'll likely find the torque spread sits much lower down the rev range, which makes it feel more willing when just pootling around town.
    Back when i had the nova, it had a 1.6 16v making 110hp, at the time craig had a nova 1.2 with 50hp. To drive them around town normally, the 1.2 felt notably more lively at low RPM's but obviously if you did plant the boot, nothing happened, whereas the 16v did very little until about 4k then took off.
    Most modern 16v engines get round this with various tricks like VVT, switchable inlet tracts, and turbochargers, but a multivalve engine without those tends to be very peaky.
  11. Broken Byzan
    13,237
    466
    like the Vtec, i really want to drive one of those @ 9k lol
  12. aragorn
    18,608
    871
    ye vtec is an example thats used to the extreme i guess, below the VTEC limit you have a VERY mild set of cams, to allow good tractability and good fuel economy, then above it you bring in a nice wild set of cams to extract good power.
    Honda actually have a few different models of VTEC, and some of the more cooking spec models have something called VTEC-E which as far as i know, basically only uses one inlet valve at low RPM's to bring the torque band right down, then uses both if you stick the boot in to give an acceptable level of power.
