any smart ar*es in here please..
ALPINE Mar 9, 2010
  1. ALPINE
    3,093
    the basecode software code to make my windows to go up with my key fob. thanks :)
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Just your windows up, or all three options?
  3. <tuffty/>
    21,785
    4,170
    smart ****.... LOL
  4. JD09
    3,096
    46
    Lol,
    +64 add window up and window down with remote.
    -04 add 1 touch unlock of both doors.
    -1024 remove horn honk when arming
    +32 autolock/unlock of doors (doors lock at 15mph and unlock when key is removed)
  5. Prawn
    11,639
    3,634
  6. ALPINE
    3,093
    ok, thats confussed me even more. is there a write up some where? i dont wanna brake the car. All i see is, "start base code" with a decode button, then a "new base code" box.
    jdo9 your way sound simpler. where and what you using?
  7. ALPINE
    3,093
  8. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Yo gummy bear! LOL! How do you do all this? Using Vag-Com?
  9. ALPINE
    3,093
    yes goof troop! lol trying to work out how is the hard part when you have never done it before!!
  10. JD09
    3,096
    46
    As above, just copied from Kev's site. The base code thing basically redoes your code for you. You input your code, select the options you want and it churns out a new code.
    But from this you can work out what it should be for separate options, +x amount or -x amount.
  11. JD09
    3,096
    46
    Where are you Alpine? If you're close to the NW, I'll do it.
  12. ALPINE
    3,093
    im in S/e london mate. i could not be any further from the NW!! lol
    if you can show me screen shots as to where to get the orig code then i should be ok. just a case of using kevs tool and replacing with the re-coded code right?
  13. JD09
    3,096
    46
    Exactly.
    Your code is the 5 digit code under "soft code".
    Search Google for "TT Tweakers PDF". Go to page 35. Read ;)
  14. ALPINE
    3,093
    soft code........ that was the bit i was after. all done now... what else can i do?? can i make it so the windows go up without me holding down the button??
  15. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    I've a sneaky feeling that can only be achieved (without additional hardware) on later model cars (IIRC it's part of the long coding on module 46 on those vehicles - can't remember exactly - it was one of many many things I tweaked on the company's Passat :eyebrows:). I'd like to be proved wrong though, it'd be a handy option to set when I'm next fiddling with one!...
    //R
  16. JD09
    3,096
    46
    As Faction (Rob?) has said, it is only available on later cars, or such has been my experience so far.
    + nice to have a new A4 estate to play on before I do anything to mine or the R8 ;)
  17. ALPINE
    3,093
    my old A4 had that funtion. must of been added by someone else. im glad i done it all anyways. my laptop has a mullerd screen, so after re-installing XP on it (had some dodgy vista on it) i plugged one of my old 15" monitors into it. worked a treat.... no the bloody back light has packed up on the screen!!! ahh well that was short lived! lol
    any 1 got a old tft/lcd they wanna loose/sell?
