Cheers. I've already posted in another thread but had no answers.Post your questions in here, plenty of S4 owners about who can help.
Does the tick increase with revs?
I'm led to believe there is an active engine mount on these that stiffens up over 10mph, it may not be disengaging.
Yes it does.
Interesting. I've read through the post you linked up, but there is no clunking or moving of the engine that I could feel. And I gave it some stick. Literally only feel it at tick over.
You sure mate? Everywhere I've checked it says it's £490. Can someone confirm please?My 2011 is £290 ?
For the exact same car. What a joke.It appears that 25 May 2010 - 26 Oct 2011 are more expensive & higher emission?
Lol. So I'm still not sure if mine is actually the higher one.£290
Just got my service book out & it says in the front on the sticker telling trim level that the emissions are 225.
Mine falls into the 490 bracket on parkers but in actual fact it is 225g/km not 234g/km
Well this says mine is £290 as well. Would be well chuffed if that is the case. Cheers!http://carfueldata.dft.gov.uk/ should give a definite answer
Carried out a bit of research for you, the S4 had emissions of 225 g/km at launch, however it seems that Audi in their wisdom made the car approx 10 kilos heavier at some point knocking it into the next tax bracket.
I do not have the exact date but I suspect this change was made sometime in 2010.
The original unladen weight was 1650 for the manual.
If you want to pay £280 road tax you need to look for an early model.
I discovered this nasty sting when shopping for S4's last year. All the manual ones I saw were £475 to tax (this is last year).
Went to look at an S4 - WTF do some people do to their cars?!
The DFT should be spot on so I think ya will be fine mateWell this says mine is £290 as well. Would be well chuffed if that is the case. Cheers!
Did ya manage to find one with the sports diff?I put a deposit down on another S4 tonight. Mint 2010 model highly specced with 43k on the clock. No funny noises or vibrations!
The one I went for in the end doesn't have the sports diff by the looks of it. I need to check through the specs properly though. Apart from that it's got pretty much everything else I wanted, plus it's like a brand new car. Didn't really want a manual or a black one, but seeing it and driving it I fell in love.Did ya manage to find one with the sports diff?
Secondly, on idle the engine felt a bit lumpy. Almost as if it had uprated engine mounts where you can feel the vibration through the seat. But once driving it disappeared.
Cheers. As long as it's normal I don't care if it plays the trumpet tbh!I know you didn't buy the car which exhibited the idle tremor, but this is quite normal and many B8 S4 owners "suffer" the symptoms. See here for example: http://forum.rs246.com/viewtopic.php?f=49&t=97228. I quite like it personally!
Bizarre they don't include one! I'll get one ordered through Audi, cheers.Audi intend you to check it through the MMI. For those who like to actually see these things you can replace that pathetic stub with a proper dip stick http://forum.rs246.com/viewtopic.php?f=49&t=115109
I actually wanted an s-tronic! But seeing as I'm strapped for time I couldn't hold out any longer.2009 s4 manual : 234 g/km
2009 s4 stronic: 219 g/km
2012 s4 stronic: 178 g/km
The older manuals are the worst for co2 emissions, and go into the top bracket, all the rest are the next one down. The s-tronic gearboxes also offer lower fuel consumption for some reason.
One of the many, many reasons I went for s-tronic
Interesting, maybe this is what my garage referred to when talking about a slight misfire on mine, it does shake slightly every now and then. Changed plugs and still there...I know you didn't buy the car which exhibited the idle tremor, but this is quite normal and many B8 S4 owners "suffer" the symptoms. See here for example: http://forum.rs246.com/viewtopic.php?f=49&t=97228. I quite like it personally!
Mine does this too and has from new. Noticeable at idle.Interesting, maybe this is what my garage referred to when talking about a slight misfire on mine, it does shake slightly every now and then. Changed plugs and still there...
Might need them to take another look
That's actually quite reassuringMine does this too and has from new. Noticeable at idle.
