Any Recommended Break Disc & pads?
guzzy_431 Jun 30, 2012
  1. guzzy_431
    guzzy_431 Member
    107
    Hay all,
    I'm due for some new set of break disc & pads. Can anyone recommend any in particular? if so, style & brand? where to purchase? & all most important price?
    Thanks in advance Y'all!
  2. Sevv
    Sevv Pushing the limits..
    1,321
    118
    Ferrodo DS2500 pads...and maybe mintex pads dont get drilled as they tend to crack.. check with Badger5, or awesome gti as im sure they stock them if not mistaken
  3. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,149
    1,986
  4. If you use your car for general use then just get standard discs and good pads (as mentioned above). Not much point in expensive discs unless you take it for track days or just like the look/feel of big, expensive brakes.
    Im just running standard discs with Mintex pads, forgotten which pads exactly but they were about £100
  5. Tooks
    Tooks Active Member
    753
    29
    I'm just running Pagid discs and pads on mine, and have no complaints. It's a standard S3 setup.
    On my old A3 TDI quattro with 288mm discs, I did run a set of DS2500 pads and they were very impressive and improved the bite and feel over std ones.
    I just haven't felt the need to change the S3 setup though, but then again I don't do track days etc.
