any posts / how tos to replace the seals on rear calipers?
epox Sep 21, 2013
  1. epox
    epox Active Member
    774
    74
    as post, just nacked the rear seals, or any good places to get calipers?
    thanks
    mark
  2. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    Never seen a how to, but they are easily done.
    You have to screw the piston out & will usually find some corrosion in the back of the original seals.
    A good clean out with a tooth brush & scriber if need be, followed by a blast through with contact / brake cleaner.
    The pistons themselves should easily clean up with a wire brush etc.
    You can get the seals through the Audi parts dept & re-assemble using silicone grease.
    Then its the usual process of fitting & bleeding.
  3. JimS3
    JimS3 Active Member
    736
    72
    Got my seals and new guide pins / boots from here, about a quarter of the price of the dealer:
    Audi A3/S3 Brake Discs - Audi A3/S3 Brake Pads
  4. epox
    epox Active Member
    774
    74
    thanks, is it 41 or 38 seals for the s3?
    mark
  5. chris99
    chris99 s3 driver
    54
    original PN is 8D0698671.. 38mm as i remember, but can check in a few hours as i have a spare kit around
  6. chris99
    chris99 s3 driver
    54
    38mm is the one you need for S3
    payed much more for an OEM repair kit which is also TRW :)
  7. JudderMan
    JudderMan Well-Known Member
    1,026
    172
    So is the 41mm for the A3 (non S3)? I'm tempted to replace the seals as I just can't justify the cost of new calipers if a seal kit is a fiver...
