Any plumbers about?
Wicked666 Sep 27, 2012
  1. Wicked666
    Wicked666 Active Member
    584
    35
    Just moved into a new house and was wondering whether I could fit a host pipe to the mains stopcock that is in the garage?
    I'm not sure but seems ideal for using with my Karcher on the car.
  2. harvey01
    harvey01 Member
    523
    9
    it looks like there is a pressure valve to down the pressure before it gose in to the house so you could cut the drain off fitting on the right put a outside tap in its place as it will work as a drain of in its place . hope it helps
  3. poverty
    poverty Active Member
    143
    54
    If you connect pre-pressure reducing valve make sure you dont use those cheap tap fitting kits, but instead just use brass fittings!
  4. Wicked666
    584
    35
    Thanks guys. I'm only renting the house so do not want to cut anything. Could I not just connect a thin hose the the bit dangling down (secure with metal clips) and turn the valve above it? Or is that not recommended? Alternative is hose through kitchen. Thanks.
  5. sportstractor
    sportstractor Chugger
    2,709
    Get yourself a 22-15-22 compression tee, a couple spare olives a bit of 22 tube, a bit of 15 tube, a new drain off, a compression 15mm equal tee, 15-1/2" back plate elbow and a bib tap with check valve. Then you will have everything you need to DIY
  6. Wicked666
    584
    35
    Thanks but didn't understand a word of that so bought this:
    Will be feeding a hose outside the kitchen window instead :)
    johnnythepie likes this.
  7. jojo
    28,944
    3,598
    lol! It will do the same job to be fair.
  8. harvey01
    harvey01 Member
    523
    9
    you could just put the hose over the drain off on the right with a jubley and use a small spanner and open it when you use it . it just turns and opens
  9. Wicked666
    584
    35
    That was what I thought and was hoping the answer would be 'yes'
    Would this cause any issues with the stop cock though?
  10. sportstractor
    2,709
    Lol, you could do that but it would be against water regs, as dirty water could potentially be sucked back into the water main. And it would be pretty annoying to use.
    If you looked in B&Q you could find everything I listed and fitted a proper tap in under an hour.
  11. jojo
    28,944
    3,598
    If you have already purchased this, then just use it, it perfectly fine, and works! Unless this hose has to go round the whole house of course, but I wouldn't mess with the pressure release valve personally.
  12. Wicked666
    584
    35
    Thanks guys - don't want to do anything that could make the water dirty. Hose does have to go round he side of the house but no real issues. Only risk is these taps have a habit of popping off but i'll put a bucket over it to protect the kitchen :)
