Any one here with xenon headlamps?
SinghB7 Aug 8, 2013
  1. SinghB7
    SinghB7 Active Member
    522
    68
    Hi all, i'm after some help locating a part.
    if anyone has a A4 Avant with xenon headlamps from factory, im after the part number of the central electrics module.
    this is located under the steering column by the fusebox. Will need to remove the cover below the steering wheel.
    if someone could help me i'd glady appreciate it.
    thanks, Singh.
  2. hades-
    9,481
    646
    i have 1 from a DTM that will work xenons
    new never used
  3. SinghB7
    522
    68
    The DTM don't have fog lights do they?
    I've retrofitted xenons but i've been told I need a highline module, is this true?
  4. hades-
    9,481
    646
    no but you can code the DTM unit to have fogs or not
    i use them when i fit DTM bumpers to code fogs out
    so it will run the xenons and fogs
  5. SinghB7
    522
    68
    Have you got the part number to hand? Also how much you after inc postage?
  6. hades-
    9,481
    646
    no its at my place in wales i can get it saturday for you
    and its £50 inc postage brand new never fitted but tested
  7. SinghB7
    522
    68
    Will it defo work in my avant? I've bought and tried 2 modules now and was told there highlines but there not.
    where abouts are you located, im in Birmingham so could pick up if you'r close.
  8. hades-
    9,481
    646
    im in sheffield
    but yes im 99% sure it will work on your car
  9. hades-
    9,481
    646
  10. hades-
    9,481
    646
    works with xenons
  11. SinghB7
    522
    68
    If you are certain it will work then I will arrange payment tomorow with you mate.
    So £50 and how much postage? Could do with 1st class so let me know how much.
    Cheers, Singh.
