any one got a boost leak tester i can borrow?
audi-a6 Feb 6, 2012
  1. audi-a6
    audi-a6 Active Member
    656
    72
    as above, located in christchrch, dorset
  2. Bradderz_1988
    3,958
    240
    Make one the fairly straight forward I used one of the end caps off an exhaust extractor pipe and pulled a tyre valve through and just got some one to keep an eye on the boost gauge whilst I charged the system with tyre pressure gauge, then just made sure I had blanked the TIP where the pancake valve is and took the engine oil cap off. It will be slightly differant on the 2.7T just have a spray bottle with soapy water at the ready you can even pull the vac line of the fpr and plum your boost gauge there if its not all wired in that is lol
    Here's the puppy I made it works a treat as it clamps straight to the MAF housing.
  3. audi-a6
    656
    72
    thanks will give it ago
  4. aragorn
    18,485
    855
    If you make one, on the corner of the Y pipe is a fitting which goes to a round plastic valve. You need to disconnect this valve from the Y pipe, and plug the hole in the Y pipe with a rubber cap (jubilee clipped on) otherwise you'll throw oil into your breathers and turn the car into a smoke machine!
  5. audi-a6
    656
    72
    excellent info...... yet again..... thanks buddy
