drummerdimitri
- Joined
- Apr 21, 2015
- Messages
- 442
- Reaction score
- 80
- Points
- 28
I find there enough torque to keep you potting along around 1700rpm and response is excellent above this but any lower and its flat, compared to my remapped 06 2.0tdi diesel its a vast improvement! but the majority of the time I try to keep the revs above 2K plus its a petrol let it rev..
Yes there is, any turbo car will lag.
But as the torque comes in quite low down (1900 rpm iirc)
Will you notice it in the real world? Absolutely not.
8P Diesel...*shudders in fear* always :'(
8P V6, power was always available.
8V, plenty of power at mid to high end but as with all turbo's you have to get used to it and know when to move, have to say it's managed very well on the S3.
To try and explain a practical example at a roundabout in the 8P V6 as soon as you know you can go in that very instant you're off at slow, medium or fast. With the 8V turbo and DSG you know if you put your foot down it's actually going to take longer to move over creeping then pushing 1/4 to 1/2 down on the gas, but you know if you do put your foot fully down you'll well.."fly".
Are you concerned about turbo lag OR are you concerned about being off boost and the spool up time/revs required before it gets a shift on .. as they are not the same thing ..?
As far as I understand it, lag is the time delay between pressing the accelerator and the turbo delivering boost when the engine speed is above the boost threshold i.e. so this could be you're at a steady @4.5K revs and press the accelerator, or you're changing gears at max speed. There will be a small delay in asking for boost and getting it, but the turbo is spinning quickly enough to deliver +ve boost.
An example would be you're waiting for a clear opportunity to overtake, sitting at 50 in 3rd. The road clears and you hit the accelerator, there will be a delay asking for acceleration and getting it. That's lag. Usually feels like a soft throttle response. The S3 (and almost any turbo car) has this (I find it frustrating).
Being off boost/not over boost threshold, is waiting for the turbo to actually spool up, so it's not spinning quickly enough to produce positive boost i.e. mashing the throttle at tickover.
So, in an older Subaru, you might have to wait until @3.5K revs for the turbo to be spinning quickly enough to produce boost. Most folk seems to think this is turbo lag, it's not, it's off boost or you haven't hit the boost threshold.
It's a bit anal I guess, but I always get annoyed when people describe Subaru's as laggy, they're not particularly. They take some time/revs for the turbo to spool, so can be caught off boost .. but once it's spinning it's not particularly laggy for a turbo engine.
Good article linked below:
http://blog.nulon.com.au/2014/05/turbochargers-turbo-lag-vs-boost-threshold/
Now my question is how can I get a more responsive engine? New intake and a down pipe perhaps?
